Leadtek Research Inc., known globally for its extreme visual graphics technology, added the new WinFast GTX 560 Ti Hurricane graphics card to the Fermi II generation family for enthusiasts. It features dual 90 mm fans, two 8 mm cooper heat-pipes, a large copper base and many fan fins equipped behind the GeForce Fermi 114 chipset, which can reduce temperature more effectively than the standard version containing only two 6 mm cooper heat-pipes from the chipset manufacture. This not only means improvements in the thermal solution but also in noise emission. Only 21 dB is measured during idle time, and even during peak time, it is just 43 dB. Leadtek will release more dual fan design graphics cards, naming them “Hurricane”, to highlight these features.
Read more here:
LeadTek Announces WinFast GTX 560 Ti Hurricane Graphics Card | Hardware Canucks
