Go Back   Hardware Canucks > NEWS & REVIEWS > Press Releases & Tech News
Old February 21, 2008, 08:42 AM
Originally Posted by DaleF View Post
It's likely cooled improperly in that case. Honestly, of many friends with 360s (and myself included) I've never seen anyone with them. From the very earliest ones to my new 65nm one with HDMI.
I have had to return 3 360's to Microsoft due to the RROD... these are not isolated incidents, the 360 is poorly designed and it shows.
Q6600@3.2ghz
Asus P5N32-E Sli
4gb OCZ Platinum DDR2 @1100mhz
Antec P180
BFG GTX 260 Core 216
Corsair HX-620
Thermaltake Power Express 250W
Raptor150, WD 500gb. WD 300GB
X-Fi Extreme Music
Old February 21, 2008, 08:45 AM
I think that's usually what it is too. I have a friend that has had the issue (RRoD) with a few of them, and it never seemed to dawn on him that it was always really hot inside the closed glass cabinet that it was in. But that was somehow Microsoft making a crappy product.
Which isn't to say that MS isn't cutting the thermals a little close on the consoles.
Consoles are designed to be stacked in cabinet style enclosures, remember this is a gaming console you are talking about, not a PC.
The fact that Microsoft is retroactively replacing any 360 that has a RROD proves there is a design flaw with the system.
Q6600@3.2ghz
Asus P5N32-E Sli
Antec P180
Corsair HX-620
X-Fi Extreme Music
Old February 21, 2008, 08:56 AM
Cheator's Avatar
There is certainly a design flaw and it should be fixed with 65nm platforms (the platform after falcon). But I agree, this is meant to be thrown somewhere, sometimes out of sight. Why should we expect less from this xbox than of the rpevious one that could run with no issue?
It was way too rushed, and it shows. Plus...thers a reason that apple moved away from PPC. MS should have learned from that :D
My Heatware![/SIZE][/FONT] | Got RMA? Tell us your experience! | VOIP Help? PM ME!
Old February 21, 2008, 09:13 AM
llama_egg's Avatar
Hehe, I heard about this yestorday, it's almost as entertaining as the Emotiv's product not working. Remember, don't be nervous, use any type of wireless devices, and have a strong brain when trying to play games....with your mind.
Also, about the red ring, apparently (was said from a "reliable source" -_-) it is caused by the heatsink they have on the CPU. So...anyone up for watercooling there 360?
Old February 21, 2008, 09:30 AM
I took apart my last 360, the cooling on the cpu is pathetic, it's a slab of aluminum.
Q6600@3.2ghz
Asus P5N32-E Sli
Antec P180
Corsair HX-620
X-Fi Extreme Music
Old February 21, 2008, 10:24 AM
MacJunky's Avatar
Unless I am mistaken the CPU has the much larger heatsink with the GPU being closer to the optical drive and having the small one..
Old February 21, 2008, 11:01 AM
I believe so, Microsoft has changed the cooling on the refurbs now though.
Q6600@3.2ghz
Asus P5N32-E Sli
Antec P180
Corsair HX-620
X-Fi Extreme Music
Old February 21, 2008, 11:13 AM
MacJunky's Avatar
Yes, however I am pretty sure I have heard of them failing as well. A slightly bigger heatsink does not seem to be quite good enough with such horrid airflow.
  #19 (permalink)
Old February 21, 2008, 11:17 AM
Since Microsoft wouldn't replace my last 360 (prior to retroactive recall), I popped off the heatsink and cleaned the the crap paste of it. I then applied AS5 screwed it back together, still had a RROD :( . Out of curiousity though, I turned the 360 on with the casing off it. I touched the CPU heatsink and I kid you not, you could evaporate water on it, is was so hot.
Q6600@3.2ghz
Asus P5N32-E Sli
Antec P180
Corsair HX-620
X-Fi Extreme Music
  #20 (permalink)
Old February 21, 2008, 11:26 AM
MacJunky's Avatar
Xbox 360 X Clamp Replacement <- this may be of interest.
You-Tube Human "Pixels" Perform Live Animation sswilson Off Topic 14 June 29, 2009 08:02 PM
how to deleted the "shared folder" create by live messenger ebdoradz Off Topic 1 January 7, 2008 12:57 PM
DirectCanada Customer Service and/or live person RacerX Off Topic 3 December 18, 2007 06:31 PM
The Death of Robert Jordan & Colin McRae SKYMTL Off Topic 12 September 18, 2007 11:34 AM
