Go Back   Hardware Canucks > NEWS & REVIEWS > Press Releases & Tech News
Old February 20, 2011, 01:04 PM
bigjee's Avatar
Originally Posted by AkG View Post
Yes and no.
Yes you will get darn near all the speed (though a little bit less)....BUT you probably wont get TRIM. Not many controllers can pass on the TRIM command soooo I would recommend against it.
Thanks for the reply.
May I ask if there is a cheap controller that can pass trim and is Sata 3 compatible.
I don't want to spend more than $30-40 and I don't want to justify a mobo switch either as that will be too cumbersome just for a gen 3 ssd.
3rd build:
Intel Q9650 (450*9) 4.05 ghz
/ 1.23Vcore
Noctua NHD14 140mm air cooler
Gigabyte EP45-UD3P Rev. 1.1
4GB G.SKILL PC2-8500 1066 Mhz (5-5-5-15)
Zotac GTX 480
Corsair HX620 modular 620W
Intel X25-m SSD + WD Caviar 640gb + 500 gb
Silverstone TJ-10 B w/ Window
HP 2709M and LNA40a530
Old February 20, 2011, 06:27 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
None that Im aware of...but then again its been awhile since I looked at cheap add-on controllers. Why not just run it off your ICH 10? Sure you will lose SOME performance...but A) its free B) doesnt require any PCI slots C) you get TRIM....and did I mention its free ;)
Then later when you do get around to upgrading your mobo...you will get a nice little speed boost. :)
OR
Just skip this gen and keep using your X25m gen 2. Its not like you got a "bad" SSD right now.
Bulldozer showcased at CeBIT (march 1st to march 5th) Delavan Reviews & Articles from the Web 3 February 3, 2011 07:00 PM
Intel Rumoured to Release Overclockable Core i5 & i7 CPUs FiXT Press Releases & Tech News 21 March 22, 2010 10:47 PM
Windows 7 Release Candidate Expiring March 1st 2010 FiXT Press Releases & Tech News 18 March 13, 2010 06:11 PM
Intel Rumoured to Release Core i7 930 in Q1 2010 FiXT Press Releases & Tech News 11 October 31, 2009 06:46 PM
AMD to launch 7 series chipsets in 2H07: Digitimes Babrbarossa Rumor Mill 1 June 16, 2007 12:42 PM
