-   Press Releases & Tech News (http://www.hardwarecanucks.com/forum/press-releases-tech-news/)
-   -   Asetek Introduces Three New Liquid CPU Cooling Solutions Supporting 92MM Fans (http://www.hardwarecanucks.com/forum/press-releases-tech-news/38450-asetek-introduces-three-new-liquid-cpu-cooling-solutions-supporting-92mm-fans.html)
FiXT November 30, 2010 11:44 AM
Asetek Inc., today announced three new liquid CPU coolers for OEMs and system builders, designed for chassis utilizing 92mm exhaust fans. The products include: a single exhaust port, single-CPU cooler; a dual exhaust port, single-CPU cooler; and a dual exhaust port, dual-CPU cooler. These new Asetek products provide superior overclocking for compac... [ Read full article ]
martin_metal_88 November 30, 2010 11:52 AM
If they are 92mm, will they fit in a standard case that can take a dual rad or the rad are smaller? Any info on the size, threading and physical spec?
Smoothie November 30, 2010 12:13 PM
So all three of these models support 92mm fans only or just the single rad version? I would be interested in the dual rad one, but if its 92mm no thanks.
Lpfan4ever November 30, 2010 12:21 PM
They're all 92mm to my knowledge, they're meant for a 3U case.
_dangtx_ November 30, 2010 12:43 PM
each block has its own pump in that duallie setup? looks good and especially fancy, at least compared to single cpu+block solutions.
im not too worried about performance, but how about compatibility. they probably couldve added an inch or two to the tubing.
Smoothie November 30, 2010 01:01 PM
Yeah the website says 92mm for all three, boo urns to that.
belgolas November 30, 2010 02:49 PM
Looks just like the H50.
Soultribunal November 30, 2010 02:54 PM
That would be because Asetek is the OEM for Corsair on those if I remember correctly.
ST
FiXT November 30, 2010 03:11 PM
ST
Yes
***extra words to fill text requirement***
mikellini November 30, 2010 03:34 PM
Although I don't see Corsair coming out with one of these...
