Go Back   Hardware Canucks > NEWS & REVIEWS > Press Releases & Tech News
  #31 (permalink)
Old September 30, 2010, 11:33 PM
Am I allowed to go against the trend and say this case actually looks pretty awesome? Especially with all the LED fan's mounted :D
That is all, you may now burn me at a stake :P
  #32 (permalink)
Old October 1, 2010, 12:01 AM
SugarJ's Avatar
While I wouldn't probably get this case for myself, I'd like to have a client ask for it. I think I'd like to see what I could do with a build in one just for fun.
  #33 (permalink)
Old October 1, 2010, 12:04 AM
you could always push..err..i mean suggest it :) i know i will.guaranteed. easy way out of playing without something and not pay out of own pocket for will i remember to snap piccies?
@kash : no ones gonna burn you maite. tis a free contry last i checkered.
  #34 (permalink)
Old October 1, 2010, 12:30 AM
unregistered
Guest
Posts: n/a
this case does not require filters. this case does not require one direction air flow. this case is best with all fans as intake. the pressure will keep all dust out.
build quality is far better then you think, for its low weight it is as sturdy as a steel case. the top handles will not break.
  #35 (permalink)
Old October 1, 2010, 04:51 PM
It looks alright until you actually use the thing.
You could get extremely frustrated. That's about the only major thing you can do with this case that you can't with others in its price range.
  #36 (permalink)
Old October 1, 2010, 04:53 PM
FiXT's Avatar
Hall of Fame
Had a chance to get up close and personal with it at PAX. Interesting case to say the least. Not entirely sure how I feel about the idea. I think it is cool, and unique, but in terms of practicality, paying $200+ for something like this just gives me a funny feeling for some reason.
But yes, the build quality is actually very good. It's not plastic pits and pieces, everything is metal.
  #37 (permalink)
Old October 1, 2010, 05:16 PM
No, absolutely not. There is a ton of plastic. The frame is metal, but the side panels, front fan mounts, screw bin, top panel, and handles are either mostly or entirely made from plastic.
  #38 (permalink)
Old October 1, 2010, 07:01 PM
MAC's Avatar
MAC MAC is offline
Associate Review Editor
The frame and mesh pieces are metal. The handles and the translucent part on top are plastic, not sure about the rest.
  #39 (permalink)
Old October 1, 2010, 07:19 PM
I have one sitting less than two feet away from me. I know exactly what it's made of.
  #40 (permalink)
Old October 1, 2010, 11:44 PM
Originally Posted by Eldonko View Post
OMG you know something is wrong when I just about spit out my coffee from laughing when I look at it. It looks like something the doozers from fraggle rock would construct
I had to laugh when I read your post.
Antec Skeleton Open Air Case Review Comment Thread lemonlime Cases 12 January 2, 2009 10:27 AM
