Go Back   Hardware Canucks > NEWS & REVIEWS > Press Releases & Tech News
Old June 30, 2010, 11:05 AM
FiXT's Avatar
Hall of Fame
Default MSI Launches Two Fuzion Motherboards for Intel and AMD
MSI is continuing the roll out of its Fuzion motherboards with the Lucidlogix's Hydra 200 chip starting with the P55A Fuzion & 870A Fuzion motherboards. The Lucid Hydra chip allow for "non-identical cross-vendor multi-GPU processing", in layman's terms, almost any combination of NVIDIA and/or ATI based graphics cards can be installed on the s... [ Read full article ]
Old June 30, 2010, 11:45 AM
bojangles's Avatar
Was the original MSI board with the LucidLogix Hydro 100 chip?
Old June 30, 2010, 11:57 AM
wasnt performance bad with them cards? i think brother sky mentioned something
Old June 30, 2010, 12:11 PM
Daft's Avatar
if i remember correctly, the original lucid based boards did scale, just not as well as standard sli/x-fire even with the same cards. this was thought to be a driver related issue. i haven't heard anything since then about performance
Old June 30, 2010, 12:24 PM
DkRk's Avatar
As much as I'd like to see Lucid's tech proliferate, one hundred sixty Washington's for an AMD 870 board is mighty steep, and that's hitting 890FX territory. The P55 also looks a little slim. Are people that want cross-brand, multi-gpu configurations really going to settle for gussied up budget boards?
Protect your chicken from Dokken.
Old June 30, 2010, 12:25 PM
Actually, the problem was that they scaled, but they scaled downwards instead of upwards. Performance with mixed cards was actually worse than with a single card.
Old June 30, 2010, 04:46 PM
Rison's Avatar
Any consumer based product that writes "Millitary Classed" across its components, makes me want to bang my head against the wall.
I'll learn to manage my anger, when people learn to manage their stupid.
Old July 1, 2010, 02:54 PM
Unregistered
Guest
Posts: n/a
stop saying some BS stuff... The hydra chips work fine, not as good a 2 same card but still better than a single card. The problem is just that it's still does not really support dedicated Physix support for a ATI/Nvidia mix.
Check this review:
Lucid Hydra 200 Multi-GPU Performance Revealed - HotHardware
Old July 1, 2010, 02:56 PM
Check this review:
Review - MSI Big Bang-FUZION: Lucid Hydra arrives | bit-tech.net
Old July 1, 2010, 03:11 PM
unregistred : register and lets hear more :)
MSI Launches N470GTX/N465GTX Twin Frozr II Graphics Card FiXT Press Releases & Tech News 21 July 7, 2010 12:25 AM
MSI Launches R5870 & R5850 Twin Frozr II Graphics Cards FiXT Press Releases & Tech News 8 May 12, 2010 08:12 PM
MSI Launches N240GT Supporting Over-Voltage, Overclocking Support by Afterburner Software FiXT Press Releases & Tech News 0 November 17, 2009 02:07 PM
MSI Launches WIND TOP AE2010 20-inch Touchscreen Desktop FiXT Press Releases & Tech News 0 August 26, 2009 02:18 PM
MSI Shows Off G41 Motherboards FiXT Press Releases & Tech News 0 July 7, 2009 12:52 PM
