-   Press Releases & Tech News (https://www.hardwarecanucks.com/forum/press-releases-tech-news/)
-   -   NVIDIA GeForce GTX 460 Pictured (https://www.hardwarecanucks.com/forum/press-releases-tech-news/33559-nvidia-geforce-gtx-460-pictured.html)
FiXT June 24, 2010 12:14 PM
NVIDIA's first card based on the GF104 GPU, the GTX 460, has been leaked by EXPreview a month before its anticipated launch. The card will offer more affordable DX11 graphics for gamers and as shown in the photos is noticeably shorter than its GF100 counterparts. The rumoured technical specs of the card are a Graphics clock of 675MHz, Processor (S... [ Read full article ]
_dangtx_ June 24, 2010 12:19 PM
nice. but still too expensive to offer a decent bang per buck response to ati.
bojangles June 24, 2010 12:29 PM
Are these chips still using the massive monolithic chip that the GTX 480 uses? If so, They are really wasting money on these lower performing cards. Looks like they're trying to nickel and dime us from all the failures they had trying to get these cards out the door...
martin_metal_88 June 24, 2010 12:54 PM
this card should be under 200 to sell it..why buy this when I can have a 5770 with the same performance for like hm...175?
ilya June 24, 2010 01:03 PM
Actually if you look at the specs, it actually seems to be a far better card than the GTX465.
Only 16 less CUDA cores, higher core/shader clocks, same or slightly lower memory interface, and significantly lower TDP. I don't think performance will be much lower than the GTX465, while having much lower consumption and heat.
Pricing is still a bit on the high side but this should be a way better card than the 5830/465. You could argue the 5770 gives better performance value, but I think this is an entirely different performance/price bracket.
But this is just speculation based on "rumored" specs.
Zero82z June 24, 2010 01:07 PM
PRICE. $270 is a complete ripoff for a card like this if it can't even come near the performance of a 5850 or 5830.
It will use the GF104, which is a smaller version of the Fermi GPU. It's not a GF100 with parts disabled like the other 400 series cards.
martin_metal_88 June 24, 2010 08:34 PM
Ok so according to what zero say ( and it's all plausible ) the smaller chip are also costy to make...wow congrat's on that one Nvidia...
fishingfanatic June 24, 2010 08:50 PM
Press Release
Agreed _dangtx_. Seems like a more reasonable card than the 465, but still priced too high.
:blarg:
Zero82z June 24, 2010 09:35 PM
I didn't say the smaller GPUs are expensive to make (although they may still be), I just said that the prices for this card are way too high if the rumours are actually true.
0o0 June 27, 2010 06:58 PM
omgg I hope that ugly card doesn't turn out to be the reference 460... looks like an ugly fat midget (no offence intended m1dget). I'll pass on this generation, thanks.
