Go Back   Hardware Canucks > NEWS & REVIEWS > Press Releases & Tech News
Old June 8, 2010, 01:11 PM
Default KINGMAX Introduces World's First Invisible DRAM Heat Spreader
KINGMAX, the world leading manufacturer of DRAM Module and Flash Products, announces the epochal product ? DDR3 2400MHz with Nano Thermal Dissipation Technology. The new product abandons the traditional heat sink which has heavy and huge size, instead of the Nano Thermal Dissipation Technology to provide higher performance and economical power.To c... [ Read full article ]
Old June 8, 2010, 01:34 PM
MpG's Avatar
MpG MpG is offline
Well, there's clearly no imminent release in English-speaking countries.
That aside, I'd love to know exactly how the coating would improve the heat conduction? The whole point of a heatsink is to offer a larger surface area to compensate for air's limited cooling abilities. Unless this is something similar to bead-blasting surfaces?
And 2 degrees isn't exactly an earth-shattering improvement where memory is concerned. And if you care about those 2 degrees, you've already got a fan aimed directly at your sticks.
Old June 8, 2010, 01:41 PM
headsh0t's Avatar
This article sounds like it was run through an online translator.
Old June 8, 2010, 01:59 PM
If I'm not mistaken, this should be based on a silicone polymer that is highly thermally conductive in one direction while being a thermal insulator in the other direction. Therefore, forcing heat away from crucial components.
I agree that this won't be much of an improvement, it should only result in slightly cheaper RAM with slightly lower temps and better clearance compared to RAM with beefy heatsinks.
Old June 8, 2010, 02:48 PM
bojangles's Avatar
The Emperor's New RAM?
Old June 8, 2010, 03:07 PM
i like heatspreaders because :
1-they look cool
2-they give ram some protection, make them sturdier
3-dust wont usually accumulate on the chips themselves, rather on the base where its easy to clean off.
4-insert here :)
Old June 8, 2010, 04:34 PM
Keltron 3030's Avatar
1-they look cool
4-insert here :)
4-They look BADA$$
FFFFFFFUUUUUUUUUUUU-
Old June 8, 2010, 04:49 PM
MpG's Avatar
MpG MpG is offline
Seriously? I had no idea that directional conductivity existed. Crazy. You'd think they'd apply this to other parts on computers.
Old June 8, 2010, 04:56 PM
gingerbee's Avatar
I really wonder if this will help oc or not just curious you know? even if just that little bit
Old June 8, 2010, 05:22 PM
Originally Posted by headsh0t View Post
This article sounds like it was ran through an online translator.
It's a press release from the manufacturer's website, written in English. And "was ran" isn't exactly proper English either
As for the product, I think it's pretty neat in that it gets even slightly better temps without a heat sink. I mean, that's just cool. I don't have an engineer's mind so I can't think of a lot of other practical applications, but I'm sure someone else can (or has).
Nvidia Introduces GeForce GTX 480m, the World's Fastest Notebook GPU mikellini Press Releases & Tech News 16 May 29, 2010 04:37 PM
invisible car cmac79 Off Topic 21 May 9, 2009 06:34 PM
DRAM Timing TheRock New Builds 7 November 25, 2008 01:46 PM
ASUS Introduces World's First Quad Core Gaming Notebook MAC Press Releases & Tech News 10 October 14, 2008 02:58 PM
Patriot Memory Reveals Updated Heat Spreader Design MAC Press Releases & Tech News 2 September 20, 2008 06:51 AM
