Go Back   Hardware Canucks > NEWS & REVIEWS > Press Releases & Tech News
Old April 30, 2010, 10:16 AM
Soultribunal's Avatar
Default Sapphire Launches HD5550 Passive Video Card
Although high powered graphics are usually on the forefront of technology, the mainstream market and HTPC segment is always one to watch. Latest from Sapphire is their HD5550 series. Being a passively cooled solution silent running is first and foremost in this cards feature set. Which should be ideal for the HTPC users or those who must have silen... [ Read full article ]
Old May 2, 2010, 11:18 AM
Oversized Rooster's Avatar
Hmmm...320 stream processors, eh?
The specs seem to suggest Sapphire's 5550 card is merely a re-badged, under-clocked Radeon 4650.
The 320 stream processors means this thing uses the older RV730 GPU (55nm) underclocked to 550MHz. They said memory is 1GB of DDR2 clocked at 800MHz.
The Radeon 4650 had the same RV730 GPU clocked at 600MHz and while it also used DDR2 RAM, it was clocked at 1000MHz.
Nothing new to see here folks, move it along...
Main: Intel 2600K @ 4.8GHz | Gigabyte P67A-UD7-B3 | 16GB Corsair DDR3-2000 | 2 x 240GB Corsair Force 3 in RAID1 | 2 x 4TB Hitachi 7K4000 | 3 x 2TB WD Caviar Black | 3WARE 9650SE | Antec 1200 | Seasonic XP-860 Platinum | 2GB GTX 670 | 2 x 27" Asus VE278Q | Auzentech Prelude | Win7 Pro 64-bit
Old May 2, 2010, 11:36 AM
Not quite. The evergreen has 1600 Stream processors, so all they did was reduce that by a factor of 5, giving 320 stream processors. Not a rebadge.
Old May 2, 2010, 11:56 AM
All 5000 series cards use RV8xx series 40nm GPUs. None are rebadges.
Old May 3, 2010, 06:26 PM
Silvgearx's Avatar
I don't see a rebadge any where either.
New TMU, DX11.
Unstable Video Card (Sapphire HD3870) sloth Video Cards 10 December 27, 2009 10:22 AM
Sapphire Launching HD 5750 Vapor-X Video Card FiXT Press Releases & Tech News 8 October 30, 2009 08:16 PM
