Go Back   Hardware Canucks > NEWS & REVIEWS > Press Releases & Tech News
Old April 28, 2010, 09:34 AM
Soultribunal's Avatar
Default Lian Li Launches New PC-T60 & PC-T7 Test Benches
When Lian Li introduces a new chassis it tends to be a thing of beauty. The new PC-T60 and PC-T7 test benches are no exception. Crafted from high quality Aluminum they are setup to provide adequate and fast access to all of your components. First on the list is the PSU rack, which is setup so your power supply can be mounted with the fan facing do... [ Read full article ]
Old April 28, 2010, 10:05 AM
Jackquelegs's Avatar
This may be the rack I've been looking for. Can't wait for some pricing
Iapetos
Zephyranthes
Old April 28, 2010, 10:19 AM
martin_metal_88's Avatar
Will probably be expensive because it's lian-li but wow I want on of those!
Old April 29, 2010, 01:06 AM
Silvgearx's Avatar
Upon opening and using the case, you will know that your OVERPRICED case is well worth it.
Old April 29, 2010, 02:11 AM
Unregistered
Guest
Posts: n/a
Exclamation lian li test rack
it looks a little, i dunno sporatic for a lian li and while its a very good first attemt where will we mount the radiators!?
Old April 29, 2010, 02:25 AM
sswilson's Avatar
Did they get tired of seeing people using their motherboard trays to make their own bench cases? ;)
As far as mounting a rad goes... easy enough to drill a few holes in the side of the motherboard tray to mount the rad using the fan screws.
Old April 29, 2010, 04:43 AM
It really just looks like a mobo tray honestly..
Iapetos
Zephyranthes
Old April 29, 2010, 08:06 AM
MpG's Avatar
MpG MpG is offline
You beat me to it
Dunno about that. Certainly interesting, but even if you're not looking for radiator mounting, there's not exactly a lot of places to mount things like fans. HDD cables will have to routed sideways and around, or they'll block one of the 5.25" slots. And it looks a little back-heavy when you get some bigger GPU's and heavier CPU heatsinks, although that could just be the angle.
Old May 1, 2010, 06:16 AM
Unregistered
Guest
Posts: n/a
Default Radiator mounting?
If you look on the lian-li website, there's a dual 120mm fan bracket that mounts so it blows over the motherboard, A 240 rad would bolt onto the back of that easy. You could also go for a 360 or 480, but it would overhang like a mofo.
Old May 3, 2010, 07:10 AM
It look like it will fall over when you push your pci-e cards into your motherboard.
Lian-Li Launches PC-7FN and PC-60FN Mid-Tower Chassis FiXT Press Releases & Tech News 7 September 4, 2009 07:27 AM
Lian Li launches PC-A70F/A71F Full Tower Chassis Gav Press Releases & Tech News 0 August 5, 2009 02:05 PM
Lian Li launches PC-8N General Purpose Midi Tower Chassis Gav Press Releases & Tech News 0 July 31, 2009 01:19 PM
Lian-Li launches the new Armoursuit PC-P50 mattlef Cases 32 June 7, 2009 08:51 PM
Lian-Li Launches Tyr PC-X2000 HTPC/Gaming Case MAC Press Releases & Tech News 0 June 24, 2008 02:43 PM
