Originally Posted by Unregistered The I5-750 isnt even based off of the 32nm series. As far as the I3s, neither are they. To assume that an I3 is more "badass" then an I5 is just an uneducated blunder.
I3s do not support Turbo Boost, so when you are running an app that is utilizing one core, it will fall far behind the I5.
I3 caps off at 3.06ghz with the 540, The I4 caps off at 3.6 with the 680, which has turbo boost of 3.86ghz (without overclocking).
Keep in mind both these chips have the same TDP. However most I3-540s can only be air cooled to 3.8ghz (roughly), Where the I5-670 has reached over 4.5ghz+ on air cooling. |
I know it's pointless, but I'll do it anyway.
1. i3's are 32nm
2. Just because something is manufactured on a smaller process, that doesn't make it better.
3. You need to educate yourself as to the difference between i3 and i5. Other than clock speeds/multipliers, the only difference is turbo boost. Have you ever overclocked one of these processors? Turbo boost only works in full auto mode; as soon as you overclock, it doesn't work.
4. If you want an idea of what these chips (both i3 and i5) can do, have a look at this:
OverClarking
