Go Back   Hardware Canucks > NEWS & REVIEWS > Press Releases & Tech News
Old April 2, 2010, 09:48 PM
rapmaster's Avatar
Originally Posted by jcmaz View Post
I think AM2+ and AM3 because the X6's have both the DDR2 and DDR3 controller... but i hope they will work on AM2 boards too.
If it's true, I'll probably buy a 960T and try to unlock or a 1055T.
Old April 2, 2010, 10:43 PM
i saw a 'news' something and it said am2+ as well. crap you could use a couple years old board from that means. even tough tdp is low, or lower than previous top end dog, one should still keep in mind the one board accomodating a six core chip should have decent or better power filtering and such.
Old April 2, 2010, 10:49 PM
Oversized Rooster's Avatar
Originally Posted by gingerbee View Post
but from early benchmarks i have read this is still slower then a 920 i7 in most cases.
Maybe so but at least you aren't forced to buy a $350 motherboard and $200 triple channel RAM kit. Overall, an AMD hexacore setup would provide much better value for the money as compared to an LGA1366 setup of any kind.
I hope AMD succeeds in putting pressure on Intel. I fully intend to upgrade one of my cottage machines to a hexacore setup just for experimentation's sake. :)
I've got 3 Athlon II 630, DDR2-based machines, 1 Phenom II 940 DDR2-based rig, 1 Phenom II 955 DDR3-based rig and the rest are either laptops or Intel based so they don't count.
I know for instance Gigabyte has introduced BIOS updates for most of their AM2+ and AM3 mobos but in terms of power circuitry would I need to buy a mid-end AM3 mobo to effectively OC a hexacore?
Currently I'm using all budget boards such as the MA78GM-US2H, MA785GM-US2H and MA785GMT-UD2H.
Machine: Intel 6800K | Asus X99-E | 32GB Corsair DDR4-2666 | 500GB Samsung 960 EVO NVMe | 6TB WD Black | 2 x 4TB Hitachi 7K4000 | Corsair 750D | Seasonic XP-860 Platinum | 4GB GTX 970 G1 Windforce | 2 x 27" Samsung S27D390HS PLS | Win10 Pro 64-bit
Old April 3, 2010, 12:16 AM
lowfat's Avatar
Awaiting some bigadv results.
Mael
Big Lian Li
Forever Alone
Old April 3, 2010, 06:40 AM
Sorry but this sound a little exagerated... You can find a good 200$ X58 board (gigabyte UD3R) and you are not forced to run triple channel....
And you will also have to include the fact that i7 overclock easy to 4 ghz.... is phenom X6 will be able to compete? Well see... (I hope so)
Old April 3, 2010, 09:06 AM
1-yes, you need a decent mobo i think
2-if its the same core as the phenom 2's, with that low tdp, i say 3.5ghz should be doable.
3-hope ppd wont disappoint :)
Old April 3, 2010, 09:22 AM
lowfat's Avatar
Yes you are considering you need at least 6GB of ram.
Mael
Big Lian Li
Forever Alone
Old April 3, 2010, 09:48 AM
Darksword's Avatar
What are you talking about? You don't need to run 6GB of ram in an X58 motherboard. Likewise you don't need to run 3x 2GB sticks either. You can use 2x 2GB just fine. Triple channel functionality is there only if you choose to take advantage of it.
And to Overclocked Rooster, you're prices are exaggerated. X58 boards can be had for under $200, and good triple channel ram can be had for under $170.
  #19 (permalink)
Old April 3, 2010, 10:32 AM
Well I think he was refering to folding -bigadv units
  #20 (permalink)
Old April 3, 2010, 11:53 AM
a truly good x58 board doesnt come cheap like p55 (150-200 you get something nice)
and yes bigadv needs truckloads of ram
Pre Order GTX480 ? [BSN] matsta31 Rumor Mill 18 February 23, 2010 05:07 AM
Bioshock 2 ready for pre-order on steam, first bioshock free BrianHanna Gaming 32 January 20, 2010 09:27 PM
mass effect 2 available on steam for pre-order BrianHanna Gaming 0 January 13, 2010 07:44 PM
Prince of Persia (PC) Pre-Order $29.99 FS & BB Thund3rball Gaming 12 January 8, 2009 07:59 AM
GTA IV Pre Order? GravyLeg Gaming 15 November 3, 2008 12:56 PM
