Go Back   Hardware Canucks > NEWS & REVIEWS > Press Releases & Tech News
Old March 9, 2010, 10:37 AM
Soultribunal's Avatar
Default Spire TherMax Eclipse II Launched
Spire has been slowly making in-roads for the PC accessories market. With their initial success it is not surprising to witness their next generation of cooling solutions. Let the Eclipse begin. Coated in a beautiful dark nickel finish and sporting twin BlackStar fans the Eclipse is sure to shine in any case with a windowed panel. Looks aside it ha... [ Read full article ]
Old March 9, 2010, 11:14 AM
martin_metal_88's Avatar
Nice looking for sure, hope to see some review soon
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
Old March 9, 2010, 01:17 PM
mr_plow_king's Avatar
Am I the only one that thinks Direct touch heatsinks are stupid ? Sure there's less material between the CPU and the heatpipes but 2 of the 5 heat pipes are not directly over the CPU. Are normal heatsinks better at dispersing the heat over 5 or 6 heat pipes ?
Old March 9, 2010, 01:25 PM
AkG's Avatar
AkG AkG is online now
Hardware Canucks Reviewer
It depends on the size of your CPU. If you are running an itty bitty 1156 then yes some are not going to come in contact. But if you are running a larger 1366 then most will be fully covered and the outer ones will be partially covered. Most HDT's weakness is not the lack of heatpipe contact, it is the fact that the fin arrays they have been paired with are too small to handle higher heat loads (like you see in heavily overclocked systems). At stock loads a Titan Fenrir (for example) destroys just about any of the solid base design's results.
"Like Lighting strikes, typically the shots you hear are the ones that didn't kill you. And as with lighting, take cover when you hear a miss...god might be finding range by walking his shots." - SM
"Pax Pro Eo Optimus Arma" - Unknown
"A society grows great when old men plant trees whose shade they know they shall never sit in." - Greek Proverb
www.nopperdogs.com
Old March 9, 2010, 01:57 PM
lets see some results at over 120w :)
Old March 9, 2010, 02:23 PM
maybe but is it a good heatsink because of the direct contact or because of the fins or both ? What I would like to see is a review of a heatsink with the same fins arrangement but with 2 bases: one direct contact and one with a solid base to see what the difference is.
Old March 9, 2010, 02:45 PM
Alas that will never come to be.
CPU Cooling is as subjective to multiple Factors as OC'ing is. There are too many variables and no CPU cooling provider is going to engineer one of each for these purposes.
Trust me, I'd like it too but it won't happen.
ST
The Below statement is True
The Above statement is False
Old March 9, 2010, 03:10 PM
AmuseMe's Avatar
I like the name It would go good with my current project "Total Eclipse" if it wasnt being water cooled.
Spire TherMax Eclipse - Keeping the Cool in Style Soultribunal Press Releases & Tech News 2 December 15, 2009 08:30 PM
OCZ Eclipse impruv Peripherals 3 December 1, 2009 11:52 AM
OCZ Eclipse 9.99 no MIR Kilauea Computer & Electronics Hot Deals 2 September 29, 2009 05:32 PM
Spire Launches SilverBlaze VGA Cooler MAC Press Releases & Tech News 2 August 2, 2008 12:58 PM
Spire Pininfarina Case sswilson Reviews & Articles from the Web 4 March 14, 2007 02:11 PM
