Go Back   Hardware Canucks > NEWS & REVIEWS > Press Releases & Tech News
Old October 17, 2007, 02:09 PM
Wankerfx's Avatar
Default Yorkfield overclock on air! INSANE!
4.65ghz was accomplished with only 1.49V and with air cooling by Hipro5.
I can't believe it! This is definitely considered news because it usually takes ~1.7V and phase change to accomplish this. ~4.5ghz should be no problem for 24/7 use with water.
I'm so glad that I waited until after the G0 phase.
On Air......not Maxed Out Yet.... - XtremeSystems Forums
[ER]
Old October 17, 2007, 02:56 PM
Eldonko's Avatar
Hardware Canucks Reviewer
Yea, those will be good chips. Faster clock for clock and clock further on same volts.
Old October 17, 2007, 03:01 PM
MpG's Avatar
MpG MpG is offline
... Well, at this point, I can safely say that it's going to take a miracle on AMD's part for my upcoming winter build to be anything but Intel-based.
Old October 17, 2007, 03:45 PM
Wankerfx's Avatar
It's crazy, running at 4.3ghz with only 1.36V is basically unheard of. AMD better show something to the community quick, before it's their trampled.
[ER]
Old October 17, 2007, 04:33 PM
Babrbarossa's Avatar
I Just bought a q6600, but if this is really the way this new series is going to perform, I'm buying one AND a new motherboard as soon as they come out.
psst, wanna see my binder?
Old October 17, 2007, 04:48 PM
MpG's Avatar
MpG MpG is offline
Those 4+ Ghz numbers are going to need much stronger FSB numbers, though, and that means no more cheapo RAM. Part of the beauty of the Q6600 is the 9x multiplier that comes with it, but thanks to Intel moving to the FSB1333, multipliers are dropping.
As far as I've been able to find, the best multiplier that will be available w/o going Extreme is now 8.5 (?), and the expected price on it is over $500.
Old October 17, 2007, 05:07 PM
magictorch's Avatar
Default immense
What a beast. Can AMD stop that-hope they get close. Cant wait to buy one after christmas...but its a shame about the multi.
Old October 17, 2007, 06:58 PM
hausner's Avatar
same
|::|CPU: i7 920 "D0"@?|::|MOBO: EVGA Classified|::|RAM: 6GB G.Skill Trident ddr3|::|GPU: BFG GTX 275|::|HDD: 2xSamsung F1 1TB|::|PSU: Ultra X3 1000W|::|Sound: Xonar DX|::|Powered by Heatkiller 3.0 LT/EK GTX275/EK Classified/Feser One X-360 TFC|::|Silverstone TJ 07
LCD: Samsung T260 25,5|::|Logitech Z5500
Project: Classified by Hausner - work in progress.
Old October 17, 2007, 07:53 PM
While the results are impressive, I generally reserve judgement until I see what retail samples are capable of ...
Old October 17, 2007, 07:56 PM
Wankerfx's Avatar
If I recall correctly; most retail C2D's did better than the ES chips.
[ER]
Problems with overclock FritzGuy Overclocking, Tweaking and Benchmarking 6 December 10, 2007 06:14 PM
Does your mobo run Yorkfield or Wolfdale? (Anandtech) Babrbarossa Reviews & Articles from the Web 8 November 3, 2007 09:16 AM
24/7 Overclock? bushwickbill Overclocking, Tweaking and Benchmarking 5 August 25, 2007 04:32 PM
Well I got one, now how do I overclock it? Supergrover Off Topic 11 May 1, 2007 02:30 PM
Intel completes 45nm 'Wolfdale', 'Yorkfield' architecture Supergrover Press Releases & Tech News 2 January 19, 2007 06:52 AM
