Originally Posted by geokilla Might get hated for saying this, but many times the PSU recommendations on a GPU box are.... well just a reference? More often than not people have been able to run their GPUs at under the recommended power ratings.
Posted this numerous times but I will always go back to this post... Corsair HX620W Power Supply Running 791W - Can't Break It!! : Cases, Power Supplies, and Cooling
Yes it not COMPLETELY stable, but it was able to run the cards fine. Two 4870X2 is quite the power hog... |
Factoring in efficiency, that PSU was actually under a load of about 630W, or 10W above its rating. And that's assuming the reading from the Seasonic Power Angel meter (which is not especially accurate) was correct.
Anyway, I doubt that this card will pull any more than 200W under typical gaming load, if even that, which means that with an average system, you'll be seeing about 300-400W of power usage while gaming. Perfectly fine for a 500W PSU.
