Go Back   Hardware Canucks > NEWS & REVIEWS > Press Releases & Tech News
Old October 20, 2009, 04:51 PM
Soultribunal's Avatar
Well the Wolf does it now on the site , same difference really.
I am sure he'll get one. So, we shall see how good it looks when real hardware is hooked up to it.
ST
www.realhardwarereviews.com
Old October 20, 2009, 07:55 PM
MpG's Avatar
MpG MpG is offline
While I like my X3 1000W, and it was top-tier a couple years ago, these aren't looking all that impressive compared to what else is out there. They don't even have their flex-force cables, which was one those things that set them apart.
A little odd how they still keep the 24-pin cable modular, as the only justification for it that I can think of is to eliminate cable clutter if you're running multiple PSU's. But since their lineup goes right up to 1600W, they wouldn't want to encourage buying multiple smaller PSU's. Also, there are very few situations that would require a second PSU, and those would be very unusual, and require a separate line out of a house's fuse box.
Old October 20, 2009, 09:22 PM
Is it 1250W max per outlet? Just wanted to clarify. I could see running two 600-700W PSU's for a power house PC to save a bit on getting something 1200+, but generally yeah it's enough.
My Silverstone Strider 750 had all modular, gotta say I prefer that to my HX1000 having some cables non modular. Just like the looks better.
Old October 20, 2009, 10:01 PM
It's per circuit. Your typical home circuit is 15A, which translates to about 1800W in general (depending on voltage fluctuations, etc.), although you should only use at most 85% of it on a continuous basis, so about 1500W. A 1200W PSU at maximum load that is 80% efficient will use 1500W, so that's basically your limit. It's pretty hard to reach that kind of power consumption with a single machine though.
Old October 20, 2009, 11:20 PM
God. Ultra. :whis tle:
Old October 21, 2009, 05:02 AM
I am unsure as to my stance on these new Andy Platforms, it remains to be seen if they were a good move or bad move.
On the positive side at least, the Line-up is expanding. Instead of starting at 850W for the Fully modular ones, they will go all the way down to 500W working their way up in 100W incriments with some 150w incriments inbetween. So at least there is more variety.
I agree that losing the Flex force Cables was a bad move. For anyone who has worked on them they know how easy it is to bend them however you need to when doing cable management.
Regards,
ST
Old October 21, 2009, 06:19 AM
I just sold my 850W Ultra X3 and I must say that it was an amazing PSU. People can say what they want but it was great. If I still needed that wattage I would never have sold it.
Current Rig: C2D E6400 @ 3.0GHz, Vendetta II, BFG 8800 GT, OCZ PC6400 8GB, HX520W, 2x WD 500GB HD, Segate 160GB, WD 200 GB HD, Lancool PC-K62, Windows 7 64 bit, Snow Leopard (on the way)
EVGA 680i SLI Motherboard $80 + Qualitas 73GB 10k SCSI $30
NEXUS Announces NX-8060 600W Modular Power Supply MAC Press Releases & Tech News 0 July 7, 2008 09:15 PM
Legit Review Has Sneak Peak - Ultra Products 2000W ATX Power Supply Supergrover Reviews & Articles from the Web 0 January 3, 2007 08:34 PM
