Go Back   Hardware Canucks > NEWS & REVIEWS > Press Releases & Tech News
Old October 9, 2009, 10:36 AM
Soultribunal's Avatar
Default Scythe Samurai ZZ - Long Live The Downdraft Cooler
Scythe has long since filled our imagination with creative and innovative solutions for CPU cooling. Living up to that long tradition we are greeted with their latest solution in a diverse market. The Scythe Samurai ZZ.
Downdraft coolers have never been embraced with the popularity held by the vaunted tower cooler. Yet, they still remain an option... [ Read full article ]
Old May 24, 2010, 07:53 PM
shenmeister
Guest
Posts: n/a
Default Only 3 heatpipes, not 6!
Although it looks like 6 heatpipes, it is in fact 3 U-shaped heatpipes as described on the Scythe website.
Old May 24, 2010, 08:07 PM
martin_metal_88's Avatar
Actually...this is 6 heatpipe no? Maybe I can't count from 1 to 6...Nice cooler for HTPC can't wait to see some result!
http://xtreview.com/images/scythe%20...%20ZZ%2003.jpg
Old May 24, 2010, 09:05 PM
actually it seems its a 3 heatpipe design. a little beast none the less
Scythe SAMURAI-ZZ 3Heat Pipes CPU Cooler
Scythe
"SAMURAI-ZZ" 3Heat Pipes CPU Cooler
Price:$ 36.50 Samurai ZZ is a new top-flow CPU Cooler weighing only 16.6 oz., respectively 495 g (included Fan), and it is equipped with 3 u-shaped Copper-Heat pipes as well as a 92 mm Fan. It is specified for cooling of CPUs with a TDP of up to 130 W. By using the improved V.T.M.S mounting mechanism, Samurai ZZ can be easily installed within just a few minutes in all common sockets including the new socket LGA1156. New F.P.S technology uses the airflow for cooling of upper and lower heatsink structure as well as surrounding motherboard components and VRs. Model Name: SAMURAI-ZZ CPU Cooler Model Name: SCSMZ-2000 Manufacturer: Scythe Co., Ltd. Japan Heatsink Dimensions: 94 x 122 x 94 mm
3.7 x 4.8 x 3.7 in
Weight: 472 g
16.6 oz. Material: x3 Heat Pipes Aluminum and Copper Material of Base Plate: Nickel-plated copper
Fan Dimensions:
92 x 92 x 25 mm
3.62 x 3.62 x 0.98 in
Speed: 300 - 2,500 rpm (regulated via PWM) Noise Level: 7.2 - 31.07 dBA Air Flow: 6.7 - 55.55 CFM Bearing Type: Sleeve Bearing Attachment VTMS Mounting Clips
Thermal Grease
Compatibility: Intel® LGA1366 Processor
Intel® Core™ i7 Processor Extreme Edition Series
Intel® Core™ i7 Processor 9xx Series Intel® LGA1156 Processor
Intel® Core™ i7 Processor 8xx Series
Intel® Core™ i5 Processor Series Intel® LGA775 (SocketT) Processor
Quad-Core Intel® Xeon® Processor 3200 Series
Dual-Core Intel® Xeon® Processor 3000 Sequence
Intel® Core™2 Extreme processor
Intel® Core™2 Quad processor
Intel® Core™2 Duo processor
Intel® Core™ Duo Processor
Intel® Pentium® Processor Extreme Edition
Intel® Pentium® D Processor
Intel® Pentium® 4 Processor Extreme Edition supporting Hyper-Threading Technology
Intel® Pentium® 4 Processor supporting Hyper-threading Technology
Intel® Celeron® D Processor
Intel® Socket478 Processor
Intel® Celeron® Processor AMD Socket AM3 Processor
AMD Phenom™ II X4 Processor
AMD Phenom™ II X3 Processor
AMD Phenom™ II X2 Processor
AMD Athlon™ II X4 Processor
AMD Athlon™ II X3 Processor
AMD Athlon™ II X2 Processor
AMD Sempron™ Processor
AMD Socket AM2+ Processor
AMD Phenom™ X4 Processor
AMD Phenom™ X3 Processor
AMD Athlon™ X2 Processor
AMD Socket AM2 Processor
AMD Athlon™ FX Processor
AMD Athlon™ Processor
AMD Socket940 Processor
AMD Socket939 Processor
AMD Socket754 Processor
FeaturesF.P.S. (Fast-Phase Structure)
Larger heatsink base and direct airflow towards lower heatsink block structure to provide a high cooling efficiency with compact heatsink dimensions.
Top Mount Fan
By pointing the airflow of the fan towards the motherboard, Chip sets and MOS-FETs on VR modules can be cooled simultaneously.
V.T.M.S. (Versatile Tool-free Multi platform System)
Improved version of Versatile Tool-free Multi platform System allows multi platform installation without any tools on the latest Intel and AMD sockets.
Old May 24, 2010, 09:07 PM
Arinoth's Avatar
Looking forward to seeing a review by HWC on this latest heatsink
Here I am: here I remain
Old May 24, 2010, 09:29 PM
Jackquelegs's Avatar
I apologize first, but this name sure reminds me of Gundam ZZ
Iapetos
Zephyranthes
Old May 24, 2010, 09:36 PM
MpG's Avatar
MpG MpG is offline
Hmm, their timing is pretty much going to put them right up against Prolimatech's new David cooler, which uses a 120mm fan. Could be an interesting shootout there.
Old May 24, 2010, 10:46 PM
Wasn't it Samuel?
Iapetos
Zephyranthes
Old May 24, 2010, 11:47 PM
MpG's Avatar
MpG MpG is offline
Originally Posted by Jackquelegs View Post
Wasn't it Samuel?
Oops, my bad. That novel they wrote for their promo brochure threw me off. Apparently, there's a competition between Prolim and Scythe for abstract naming of heatsinks.
Still, it'd be nice to see a good review involving the two. I'm probably moving to an LC20 sometimes in the next few months, and I'll need a low-profile air sink until I get the water sorted out.
Old May 25, 2010, 06:08 AM
Water cooling in a LC20? wow taht would be nice! I am still not understanding why Scythe claim it's a 3 heat pipe when we clairly see 6. Are the U under the cooler on the contact area? maybe.
Scythe Mugen 2 CPU Cooler Review FreeKnight Member Reviews 9 September 7, 2009 07:43 PM
Scythe Musashi VGA cooler review stoanee Member Reviews 11 June 6, 2009 02:57 PM
Keep Your Brain Alive - Live Long & Prosper misterlarry Off Topic 1 May 13, 2009 09:37 PM
Massive new Scythe cooler?! Cptn Vortex Press Releases & Tech News 26 March 3, 2008 05:43 PM
Massive Scythe Cooler, among others. Cptn Vortex Rumor Mill 8 November 29, 2007 02:11 PM
