Go Back   Hardware Canucks > NEWS & REVIEWS > Press Releases & Tech News
Old September 28, 2009, 05:02 PM
Caldezar's Avatar
Default Intel's 'Light Peak' Technology achieves 10Gb/s transfer
So I was reading up on tech news and came across a write-up on Intel's 'Light Peak' technology. I've seen this tech rumoured before, but I was surprised to see the actual numbers.
(Taken from Gizmodo, article written 09/23):
Today at IDF, Intel unveiled Light Peak technology, a plan for an extremely high-speed optical cable they hope will land on consumer products in 2010. Imagine transferring an entire Blu-Ray disk in 30 seconds. And that's just the beginning.
In Intel's words:
Existing electrical cable technology in mainstream computing devices is approaching practical limits for speed and length, due to electro-magnetic interference (EMI) and other issues. However, optical technology, used extensively in data centers and telecom communications, does not have these limitations since it transmits data using light instead of electricity. Light Peak brings this optical technology to mainstream computing and consumer electronic devices in a cost-effective manner.
Light Peak delivers 10Gb/s speeds right now, and could conceivably go as fast as 100Gb/s within a decade or so. Those kinds of speeds are even sustained over a 100-meter distance, which is really impressive. Intel is currently working with hardware manufacturers (computers, handhelds, etc) to try to get the optical tech onto devices sometime in 2010.
(Original source: Intel)
Now, this technology is supposed to ship by 2010. And we have no hardware that can even come close to taking advantage of it at the moment. (Especially in the optical drive department they use as an example.) But this certainly bodes well for the future of solid state drives, and other technology pushing the boundaries of speed. It'll be interesting to see if this becomes a new standard, or just a platform to set the stage for several mediums.
Old September 28, 2009, 05:23 PM
muse108dc's Avatar
from what I've heard its actually an Apple proposed concept, and is expect on the Fall 2010 updates of macs.
And for the most part USB 3.0 is fast enough for harddrives, and even SSDs for the most part, there is no external use for it
Old September 28, 2009, 08:04 PM
MacJunky's Avatar
They _really_ _really_ need to pair the optical cabling with 4 wires. 12v, 5v, 3.3v and ground. Also need to let you carry a decent amount of current over em. That way our devices would not need two cables going to them, data and power. You could run your 3.5" HDD/SSD off a single cable! Sure you can squeak a 2.5" by on USB if you use two ports, FireWire is awesome in this regard but light peak could beat the piss out of them both if it had a good amount of power supplied along with the data in one connector.
Old September 28, 2009, 08:06 PM
muse108dc's Avatar
yes, power is probably more important than speed for future connectors, would be so nice to be able to plug in my external harddrive without having to bother finding a spare power plug.
Old January 11, 2011, 06:49 PM
gingerbee's Avatar
yes it's an old thread and i am too trusting of the source but here some more info on it http://www.tomshardware.com/news/cop...ter,11960.html
If it's using copper does this not mean it will be limited quite a bit by said copper connections ??
Old January 11, 2011, 11:44 PM
MacJunky's Avatar
What the hell? So what is the point if it is not optical? We have plenty of copper crap already. -_-
Starting out with copper then transitioning to optical will hurt adoption! People and mfgers are going to go: "bugger this, I am going to use USB/eSATA because I know my shit will still work with it later on."
I want to know what is really at play here. It appears to be quite fishy.
Intel to Scrap Braidwood Technology From P57 Series. FiXT Press Releases & Tech News 7 August 19, 2009 03:00 PM
Braidwood Technology - Intel's Golden Child Soultribunal Press Releases & Tech News 0 July 15, 2009 11:09 AM
iTunes Transfer darkorb Networking 3 September 10, 2008 06:55 PM
Intel Virtualization Technology??? sswilson CPU's and Motherboards 5 May 30, 2007 03:33 PM
HardwareZone has a first glimpse of Intel's 45nm process technology Supergrover Press Releases & Tech News 0 January 29, 2007 12:46 PM
