Go Back   Hardware Canucks > NEWS & REVIEWS > Press Releases & Tech News
Old April 8, 2009, 02:39 PM
Shadowmeph's Avatar
Default Mcr220-qp-stack
I was pointed to this by someone on a different forum and thought it was pretty cool and never even knew they existed. I checked the NCIX site but the search came up empty
Swiftech MCR220-QP (Quiet Power™) Stackable Series 2 x 120mm Radiator Products Model: MCR220-QP-STACK [MCR220-QP-STACK] : Performance-PCs.com, ... sleeve it and they will come
Old April 8, 2009, 02:53 PM
Its been out for awhile but there is no real use of them so they don't sell many.
Old April 8, 2009, 03:09 PM
MpG's Avatar
MpG MpG is offline
It's a neat option, although the jury is still out on exactly how much improvement the second radiator gets you. Have to really plan things out in advance, because 2 rads + fans makes for a pretty massive brick to mount somewhere.
Old April 8, 2009, 04:28 PM
Shadowmeph's Avatar
what about this XSPC RX240 XSPC RX240 Extreme Performance Radiator - Thermochill Killer Part II Products Model: RX240 [RX240] : Performance-PCs.com, ... sleeve it and they will come what this be a better option?
Old April 8, 2009, 04:54 PM
JD JD is offline
I'd say so.
Stacking radiators usually doesn't yield that great of a performance increase from the couple tests I've seen. Unless you have some fans with crazy pressure I guess, though then you have a far from silent system.
Old April 9, 2009, 04:54 AM
CanadaRox's Avatar
Originally Posted by jdrom17 View Post
I'd say so.
I think the advantages of using stacked rads are the same advantages to using rads requiring high pressure fans such as the BIX series. If you have fans with enough static pressure, it'll yield good results, where as if you have more standard fans the temperature change wont be as much.
Project: Black and White
Old April 9, 2009, 05:07 AM
Soultribunal's Avatar
I would prefer a double thick Single Rad , with double Pass as opposed to that. Then again, thats just me.
I also think that they need to make these things Solid Copper to really achieve the benefit they can offer, or solid Silver .
Still it is a really cool design, and I could see some application for it somewhere.
ST
www.realhardwarereviews.com
Old April 9, 2009, 05:09 AM
MpG's Avatar
MpG MpG is offline
Actually the Feser and the XSPC RX rads are all copper.
Old April 9, 2009, 05:37 AM
Really? Thats cool, I always thought they were Brass Cored.
I stand corrected then.
ST
Old April 9, 2009, 06:53 AM
MpG's Avatar
MpG MpG is offline
Yeah, pretty much all the rest of the 'Copper' rads are brass cored with copper fins. This whole 100% copper coring is fairly new to mainstream, from what I understand, and I'm pretty sure that's one of the reasons the Feser and XSPC rads perform so well.
Rehashed TJ09 - MCR220 and PA120.3 ChuckleBrother Water Cooling 2 March 1, 2009 07:39 PM
[FS] Samsung Ext DVD drive & MCR220 rad Sniper Buy/Sell & Trade 12 January 3, 2009 02:50 PM
water cooling a p182 - top mounting a MCR220 nikitos Water Cooling 6 March 20, 2008 05:14 AM
Stack 830 SLI setup Robilar(OCN) Case Mods, Worklog & Gallery 9 March 16, 2008 01:19 PM
