Go Back   Hardware Canucks > NEWS & REVIEWS > Press Releases & Tech News
Old June 12, 2007, 05:47 AM
Babrbarossa's Avatar
Default COOLINK introduces the Silentator CPU Heatsink
These are the people that manufactur Noctua's stuff, so if the price is right, this might be a good choice for those looking for some peace- only 14dBA
The Silentator's mission is simple: to cool - and to do it silently! Employing 3 high-performance dual heat-pipes, an optimised fin-design and a SWiF-1202 quality fan, the Silentator achieves first-class cooling performance at a minimum noise of only 14dB(A)!
For the Silentator, Coolink could build on the basis of Noctua's much acclaimed Ultra-Low-Noise coolers, which are manufactured in Coolink's factories and earned more than 100 recommendations and awards from international websites and magazines. The Silentator also employs their professional SecuFirm™ mounting system. Thanks to the use of 3 high-performance Dual-Heatpipes, the performance-optimized design of the cooling fins and a SWiF-1202 quality fan, the Silentator achieves outstanding cooling performance. At the same time, the noise emission of the SWiF-1202 can be reduced to a mere 14dB(A) using the supplied PCI-bracket fan controller. As a result, the Silentator is suited not only for harsh overclocking, but also for real Silent-PCs!
  • 3 high-performance Dual-Heat-Pipes
  • 37 Aluminium-Fins with a surface area of more than 3500cm²
  • Soldered joints for optimal heat-transfer
  • Original SWiF-1202 quality fan with high precision double ball bearing
  • Adjustable between 14 and 24dB(A)
  • Tool-free fan-mount including anti-vibration strips
  • Original SecuFirm™ mounting system*
  • Can be turned by 90° for optimal positioning and compatibility
  • Available for LGA 775, AM2 and K8 (754, 939, 940)
  • 36 months warranty
* The SecuFirm™ mounting system guarantees optimal contact pressure and maximum security thanks to the use of a backplate and spring-loaded screws. As a result, the SecuFirm™ mounting system makes it possible to safely transport the assembled system without any risk even though the cooler exceeds the 450g weight specification established by Intel and AMD. Perfect for LAN gamers!
Coolink Silentator CPU Cooler Review Comment Thread SKYMTL Air Cooling 7 April 22, 2008 08:20 AM
NVIDIA introduces APX 2500 supernode Video Cards 3 February 12, 2008 02:42 PM
Swiftech Introduces it's new waterblock for NVidia GeForce 8 series Babrbarossa Press Releases & Tech News 1 June 3, 2007 12:54 PM
