<~----> VR-Zone & EVGA Forums - EVGA X58 SLI Classified - NF200 Monster! - Hardware Canucks
Go Back   Hardware Canucks > NEWS & REVIEWS > Press Releases & Tech News
Old January 8, 2009, 07:01 AM
zlojack's Avatar
Default VR-Zone & EVGA Forums - EVGA X58 SLI Classified - NF200 Monster!
EVGA X58 SLI Classified Preview - VR-Zone.com: News and Reviews
http://www.evga.com/forums/tm.asp?m=716976&mpage=1&key=򯂰
NAKED BOARD
TWO-WAY SLI
3-WAY SLI + SOUND CARD + PhysX
A new X58 Motherboard makes it’s debut: The EVGA X58 SLI Classified:
First let’s take a look at the specs of this Motherboard:
CPU Socket:
  • Socket LGA1366 for Intel Bloomfield processor
  • Support QPI(Quick Path Interlink) up to 6.4GT/s, base on 20bit-width up to 25.6GB/s
Chipset:
  • X58+ICH10R chipset (Tylersburg) with NVIDIA nF200 X16
System Memory:
  • Six 240-pin DDR3 SDRAM DIMM sockets
  • Support 1.5v DDR3-1066/1333 DIMMs with triple channel architecture
  • Support x16 and x8 DIMMs, non-ECC, DIMMs
  • Support up to 24GB system memory
Expansion Slots:
  • One PCI connectors compliant with PCI v2.3
  • One PCI-Express (x1) connectors compliant with PCI Express 1.0a
  • Four PCI Express (x16) connector compliant with PCI Express 2.0
  • First PCI-E x16 bandwidth x16 fixed, signal from X58
  • Second PCI-E x16 bandwidth x16 fixed, signal from nF200 X16 channel A.
  • Third PCI-Ex16 PCI-E x16 bandwidth x16 or x8, signal from nF200 X16 channel B
  • Fourth PCI-Ex16 PCI-E x16 bandwidth x8, signal from nF200 X16 channel B
In other words, 3-way SLI @ Full x16 Bandwidth per slot or 3-way SLI @ x16x16x8 with x8 VGA dedicated PhysX or GTX295 Quad SLI @ x16x16 + GTX 295 dedicated PhysX @ x16
USB:
Twelve USB connectors compliant with USB2.0 from embedded USB controller (8 connectors at rear panel)
P-ATA IDE:
One IDE ports (up to 2 IDE devices) with UDMA-33, ATA-66/100/133 support from JMB363 controller
S-ATA:
  • Six S-ATA II ports with up to 300MB/s from chipset with RAID 0,1,0+1,5
IEEE 1394:
  • Two IEEE 1394 port from TI TSB43AB22A (1 at rear)
More S-ATA:
  • Four S-ATA II from JMB363 and JMB362 controllers (1 at rear panel from JMB362)
LAN:
  • TWO Gigabit Ethernet from Realtek RTL8111C Gigabit Controller
Audio:
  • Selectable 2, 6 or 8-CH audio from Realtek ALC889 (Colay ALC888S,ALC888) HDA compliant CODEC
  • Support rear panel SPDIF, Coaxial output
  • Support Front panel audio for Mic-In and stereo Line-out only
  • (Front panel Line-out electrically shared with rear panel Line-out).
  • Support Jack detection for fool-proof audio device installation
I/O:
  • Onboard Fintek 71883 LPC bus I/O controller
  • Legacy peripheral interface for PS/2 keyboard
  • Support Hardware Monitoring for fan speed monitoring, CPU and System temperature.
  • Intelligent fan speed control for CPU-fan (PWM) for quiet operation
BIOS:
  • 8Mb Flash SPI EEPROM with Award Plug & Play BIOS
  • Support ACPI S3 (Suspend To RAM) mode in ACPI compliant O/S
Special Features:
  • Support KBPO (Keyboard Power ON) function
  • Support USB resume in S3
  • Support Wake-On-LAN by PME
  • Onboard 80 Post-Port LED display
  • Onboard Button for convenient power-on, Reset, Reset CMOS
  • Support Asynchronous clocking mode
  • Dual ATX12V 8pin power Connectors for CPU
  • PCI-E Slots Disable Jumpers
  • V_Core, V_DIMM, VTT, IOH, CPU PLL, QPI PLL, ICH IO, ICH Ground measure points
  • EVGA Control Panel via Extension Cable
Form Factor:
  • 300mm x 265 mm x 40mm, ATX Size, 8 Layers PCB
Supported O/S:
  • Windows XP/Vista
Accessories:
  • User’s manual
  • User Quick Guide
  • Three way SLI bridge cards x 2
  • Two way FPC SLI Bridge card
  • IDE cable , 6 S-ATA data cable;
  • 2 USB+1 1394 bracket Cable
  • EVGA Control Panel & Cables
  • CD for drivers, utilities and bundle software
  • IO shield
[SIZE=3]
Old January 8, 2009, 07:59 AM
Chilly's Avatar
The ability to Quad SLi(2x GTX295) plus one GTX295 for PhysX's should MURDER any 3dMark Scores out there. Wonder how it would do in games though.
Old January 8, 2009, 08:00 AM
zlojack's Avatar
I'm going to wait until right near the end of my step-up period before I make the call on this board.
I've already got the Bitspower chipset blocks for mine, so that's another expense. This thing does look like a fine piece of engineering, though. Mighty fine.
[SIZE=3]
Old January 8, 2009, 10:33 AM
kruzn4evr's Avatar
I just ordered the x58 so stepping up could be an interesting proposal in the next 3 mths. I think I better start buying an extra 649/super7 ticket to pay for those 2x 295's
Old January 8, 2009, 12:05 PM
MpG's Avatar
MpG MpG is offline
Interesting, although that NB heatsink is over the top. Fin density is way more than optimal for passive cooling. It doesn't mention it in those specs, but this board apparently has 10-phase CPU power, instead the eight that the normal X58 board has. Nice touch on skipping a card slot beneath the first PCI-E slot. Nobody buying this board is putting anything in that particular space anyway.
Old January 8, 2009, 03:57 PM
belgolas's Avatar
jaw dropping awesome. I may have a step-up in the future although I am just gonna enjoy my system for awhile.
Sponsor a child!
Fight poverty.
Qoute by Perineum
"ID10T. I just BETCHA he's got 9 toolbars on his web browser right now."
Old January 8, 2009, 04:55 PM
That looks incredible. With the spacing of the PCIEx16 slots, you could even fit one of the monster 3-slot cards from Palit. It even has that PCIEx1 slot for a discrete audio card, you don't see that on many 3-way GPU boards.
I'm not sure what to think about NF200 yet. HardOCP recently released some benchmarks showing that a x16/x8/x8 config without NF200 actually achieved a higher framerate than x16/x16/x16 with NF2000. They speculated that NF200 may introduce some latency issues.
But regardless, that it still a very impressive looking board.
Old January 8, 2009, 05:06 PM
What a board.. fitting 3 dual slot video cards, physx card and a bloody sound card.. mayhem!!
Did you notice one stupid thing, there is a SATA port near the first PCI-E slot, and with those bulky video cards, how do you get a sata wire in there..
But zlojack, awesome find!!.. You've been recently blessed my eVGA lol!.. :P
Old January 8, 2009, 07:27 PM
belgolas's Avatar
that sata cable is useful for an esata bracket on the back as you don't have to get a sata cable all the way to the other side of the mobo.
I am definitly steping up to this mobo if it is in a reasonable price. I plan that this will be my mobo for a few years lol.
Sponsor a child!
Fight poverty.
Qoute by Perineum
Old January 8, 2009, 07:47 PM
off course I know, but at least they could have relocated it, or placed it in a better spot.. Imagine people who actually do use that slot, it will be a nightmare for them at least.. Just Imagine :P
Evga 8800 gt: Nvidia VS Evga drivers TwystedMonkey Video Cards 4 September 1, 2009 01:57 PM
[FS] Fs evga gtx 260 TerenceJ Buy/Sell & Trade 8 November 24, 2008 04:40 PM
EVGA X58 kruzn4evr CPU's and Motherboards 14 November 17, 2008 07:29 PM
Fs: Evga 9800gx2, Evga 8800gts (512) Evilyeti Buy/Sell & Trade 15 October 27, 2008 02:05 PM
FS: EVGA GTX260 - EVGA 750i FTW kenken3686 Buy/Sell & Trade 2 October 2, 2008 07:28 PM
