Go Back   Hardware Canucks > NEWS & REVIEWS > Press Releases & Tech News
Old May 14, 2007, 04:26 AM
Babrbarossa's Avatar
Default AMD's Phenom: Anandtech
Well here's the verdict: It's called the Phenom and it's 100% cbackward compatible with AM2 motherboards- it would have been good for them if they had been able to announce that months ago!
At the top of the product lineup we have the Phenom FX processors (codenamed Agena FX). These processors will be quad-core only and run at the highest clock speeds in AMD's lineup, much like the current Athlon 64 FX. At the Quad FX introduction, AMD indicated that FX processors would be Socket-1207 only, simplifying its product lineup. Unfortunately, AMD has once again reversed its decision and Phenom FX processors will be available in both Socket-1207 and Socket-AM2 flavors.
The Phenom X4 and X2 processors are the sensible versions of the Phenom, these are the ones we will most likely be recommending out of AMD's lineup if history holds true. The X4 and X2 will be Socket-AM2/AM2+ only and are 100% backwards compatible with current AM2 motherboards.
The current Athlon 64 X2 has been renamed to the Athlon X2; given that both AMD and Intel offer 64-bit processors, dropping the 64 from the name makes sense. At the bottom of the list is AMD's Sempron, which is the only single core brand in the product lineup.
AMD hasn't updated us on other details for Phenom, which is a bit odd given how much more forthcoming AMD has been privately about other aspects of its microprocessor plans. Either AMD is doing its best to hide a rough ramp of Phenom or it is sitting on a very powerful weapon to combat Intel with, and we can't get any indication of which it is.
More from Anandtech
Old May 14, 2007, 07:26 AM
CMetaphor's Avatar
Quadfather
OH Booyeah! Can you say booyeah? Yes! All AM2 Owners, time to say Booyeah!!
Old May 14, 2007, 07:34 AM
BooYeah- I'm glad to see it in writing from a reliable source that it's 100% compatible- it is too bad that this wasn't out earlier, otherwise there would have been alot more people following the same upgarde path as you, CMet
Old May 14, 2007, 07:38 AM
sswilson's Avatar
Doesn't really tell us anything new other than the fact that they have plans to upgrade the new core in 2008.
The 100% backwards compatible is the same we've already heard about.... it's backwards compatible but there will be a slight performance hit over a AM2+ motherboard. (And from the way they're describing the differences I'm betting that OCers will be the ones who most see that performance hit).
That said.... I'm hoping that their recent lifting of the "cone of silence" (c'mon folks... time to show your age again.... :) ) means that they are fairly close to releasing the new proc. AMD users everwhere are getting tired of waiting.
Old May 14, 2007, 07:45 AM
Do you have any recent links that talk about the performance hit? I thought perhaps that would have changed since the went from HT3.0 back to 2.0 for the upcoming chips.
Old May 14, 2007, 07:47 AM
sswilson's Avatar
it loses the ability to run its Northbridge and CPU cores at separate voltages/clock frequencies. If you buy a new Socket-AM2+/Socket-1207+ motherboard, then the CPU cores and Northbridge can run at separate voltages/frequencies. The benefit of doing this is not only power savings, but AMD has indicated that it can actually run the Northbridge faster than the CPU cores (by 200 - 400MHz) which will improve performance. The L3 cache happens to run on the same voltage plane and at the same frequency as the Northbridge, compounding the performance benefits of using a new "plus-socket" motherboard (Socket-AM2+/Socket-1207+).
From the same article.
Old May 14, 2007, 07:52 AM
HAHA- thanks- I must say my slow connection forces me to be a bit of a 'selective' reader- that looks like it might be fairly significant...
Old May 14, 2007, 07:58 AM
sswilson's Avatar
It does sound interesting from an OCer point of view though.
One more major setting that can be tweaked on it's own to get max performance. (Almost like getting another memory freq to play with).
Old May 14, 2007, 08:15 AM
Eldonko's Avatar
Hardware Canucks Reviewer
I think it's smart to hold the switch to DDR3 until it becomes more mature. Intel can do all the DDR3 adoption when it is overpriced and performs poorly, then AMD can adopt when it gets cheaper and better. Just like w/ DDR2.
AMD delays Phenom 2.4 GHz due to TLB errata 1Tanker Rumor Mill 8 November 19, 2007 05:59 AM
AMD Phenom CDN $ prices qwerty Rumor Mill 2 November 14, 2007 05:15 PM
AMD's Barcelona quads are here at NCIX belgolas CPU's and Motherboards 10 September 13, 2007 09:34 PM
AMD's DX10...stinks? Babrbarossa CPU's and Motherboards 7 June 5, 2007 07:23 AM
AMD prepares its Phenom FX, Phenom X4 and Phenom X2 lineups Babrbarossa Press Releases & Tech News 1 May 4, 2007 07:38 AM
