Go Back   Hardware Canucks > NEWS & REVIEWS > Press Releases & Tech News
Old November 7, 2008, 07:26 PM
Default WPA Cracked.
Tool to Crack Wi-Fi's WPA Will Appear Next Week - News and Analysis by PC Magazine
Tool will be out next week apparently.
Old November 7, 2008, 07:41 PM
sswilson's Avatar
Interesting, but it's not going to change the way I use my wireless connections.
I've always treated a wireless connection the same way I treat my cordless phone.... I automatically assume that somebody could be listening in if they really want to.
Old November 7, 2008, 07:42 PM
3.0charlie's Avatar
It was just a matter of time.
Hydro-Quebec is salivating...
Old November 7, 2008, 07:55 PM
I actually use encryption and MAC address locking just for added masures. I'm sure someone could clone a MAC address somehow but I'm not sure it's all that easy lol.
Old November 7, 2008, 08:16 PM
Spaceman-Spiff's Avatar
And I'm still using WEP cause of my NDS :(
For those who care about security, switch to WPA2 or AES.
Follow up news...
"The reports earlier today on WPA's TKIP key type being cracked were incorrect. I spoke at length with Erik Tews, the joint author of the paper that discloses a checksum weakness in TKIP that allows individual short packets to be decrypted without revealing the TKIP key. I wrote this up for Ars Technica with quite a bit of background on WEP and WPA. Tews's paper, co-written with Martin Beck, whom he credits as discovering and implementing a working crack (in aircrack-ng as a module), describes a way to use a backwards-compatible part of TKIP to exploit a weakness that remains from WEP. ARP packets and similarly short packets can be decoded. Longer packets are likely still safe, and TKIP hasn't been cracked. Don't believe the hype, but the exploit is still notable."
Source: Slashdot | The Real Story On WPA's Flaw
Old November 7, 2008, 08:19 PM
lowfat's Avatar
werd. WPA2, SSID off, MAC address locks. I feel pretty safe.
Old November 7, 2008, 08:50 PM
Supergrover's Avatar
Here I thought I was the only one actually using MAC locking
While fairly easy to get around its still 1 more level of safety.
R.I.P.
Old November 7, 2008, 08:51 PM
sswilson's Avatar
I've always used the "block all macs but the ones specified" settings on my routers, but still wouldn't trust wireless to do my banking.
Old November 7, 2008, 09:04 PM
With a very large yard and little to no neighbors I probably don't even have to worry, I doubt that anybody could get a signal unless they came into the yard.
R.I.P.
Old November 7, 2008, 09:07 PM
CanadaRox's Avatar
There are many tools available that will let you find the MAC address of active clients and let you fake your own, so it only really prevents the most basic of hackers. But, every extra level helps. I personally have SSID disabled (again fairly easy to bypass), MAC filtering to only allow set clients and WPA2 personal (it would be enterprise if it wasn't for my brothers MacBook) and a WPA key of randomly generated characters (letters/numbers/symbols, which is a PITA to type, but worth it IMO).
Project: Black and White
