Go Back   Hardware Canucks > NEWS & REVIEWS > Press Releases & Tech News
Old October 26, 2008, 09:59 PM
MAC's Avatar
MAC MAC is offline
Associate Review Editor
Default Scythe Introduces Kama Angle CPU Cooler
Scythe have just introduced the new Kama Angle CPU cooler, which as you may have surmised features an angled design.
"Scythe Co., Ltd (Tokyo, Japan) announces its newest CPU-Cooler. Together with Quietpc.com, there was a product developed which uses a unique design to fit everybodys’ needs.
The special angular shape of the cooler allows to optimize the airflow through a PC system by utilizing the PSU and rear case fans. For perfect compatibility and flexibility, Kama Angle can be mounted in four different directions.
Scythe supplies Kama Angle with a new ultra silent SlipStream-fan, which uses PWM. The PWM-technology allows a temperature-dependent regulation of fan speed directly controlled by mainboard BIOS and is supported by lots of motherboards available on the market. The supplied fan can be mounted in three different ways to supply optimal airflow inside the case.
Kama Angle is compatible with all current sockets. Mounting accessory for Intel Socket 478 and LGA 775 is supplied as well as for AMD Socket 754, 939, AM2 and AM2+.
Scythe uses materials of highest quality. The baseplate consists of nickle plated copper to avoid corrosion of the used material.
The Kama Angle can be purchased from now on for an MSRP of XXX $ / 29.90 Euro excl. VAT."
Press Release.
Product Page.
Old October 26, 2008, 10:51 PM
MpG's Avatar
MpG MpG is offline
Bleh. Who's the genius that put that design together without any shroud?
Old October 26, 2008, 10:56 PM
Jon_di2's Avatar
Ya it does look a little ugly... and its also push pin for some reason?
EVGA780i FTW|Q9450@3.3|2x2GB Mushkin Redline 8000|GTX 260 Core 216 65nm|Corsair TX750|Antec 900|Acer 22|Antec Multimedia Premier|WD 640GB|Seagate 500GB|Logitech G15|Vista64
EVGA790i FTW|E8400@4.1|4x1GB Aeneon Xtune DDR3-1866|2xGTX 260 55nm|CM 750W| CM690|Viewsonic 25.5|Seagate 500GBx2|Logitech G5|Razer Lycosa|Scythe Kaze Master 5.25|Win7 & XP
Dell XPS M170|Pentium M @2.00|2GB DDR2 @667MHz|Nvidia GeForce Go 7800 GTX|120GB|17" WUXGA|XP32
Old October 27, 2008, 12:20 PM
lemonlime's Avatar
Hardware Canucks Reviewer
Looks like a sideways version of the Scythe Kama Cross. Looks like you can mount dual fans facing the other direction, thankfully.
Old October 27, 2008, 12:46 PM
MpG's Avatar
MpG MpG is offline
It's not whether it looks good or not, but without a shroud to force the fan to pull air through the fins, there's no way that fan is going to be working anywhere maximum efficiency. I lose a full degree on my TRUE just from the 1/4" gap between the fan and the fins at the top. On this heatsink, with that huge gap, it'll be brutal. Now, if there's room, mounting a pair of fans on the outside would eliminate that issue, although there's no telling what other components that will interfere with.
