Go Back   Hardware Canucks > NEWS & REVIEWS > Press Releases & Tech News
Old September 22, 2008, 08:13 AM
CTA's Avatar
CTA CTA is offline
Default TRUE copper version - coming soon
http://en.expreview.com/2008/09/18/u...n-coming-soon/
um... i want one?
Old September 22, 2008, 08:52 AM
I love the writers errors though, "3.0kg" JESUS, that's over 6 pounds! LOL but he meant 3lbs lol 1.5kg!
Old September 27, 2008, 04:16 PM
Alwaysrun's Avatar
I don't think I'd want one. Correct me if I'm wrong here but the last I read on the topic having a copper base going to aluminum heat spreaders is far more efficient than just copper alone. I read in an indepth analysis of thermal properties that stated while copper is more efficient at conducting heat that aluminum is superior in dissapating heat and thats why the lions share of HS models use this principle. It's all fine and well that copper can trap the heat but it's efficiency in getting rid of it from it's denser structure takes a back seat to aluminums ability to radiate that heat into the air. Regardless if I won the 6/49 I'd grab one cuz the bling factor would be something to behold and damn the .004 degree heat dissipation haha.
Old September 27, 2008, 06:21 PM
S_G's Avatar
S_G S_G is offline
Heatpipes, no. The fins, yes. Cu has a greater thermal conductivity than Al, therefore, it is easier to transfer heat to Cu. However, Cu also has a greater mass than Al. As such, Cu will retain more heat than Al -- that is why Al dissipates heat better.
Ideally, the best solution is to have more all-copper heatpipes with direct contact to the heatspreader (the like Xigmatek's HDT-S1283). Then, the fins should be aluminum, because fans blowing on aluminum fins will cool faster due to the lower mass.
Edit: Well, I just did some quick research on the subject. This page on OCF has some good info on the matter. It points out that my idea of Al fins may be incorrect. However, I am not convinced that of two properly designed and machined heatsinks, one all Cu and the other Cu+Al fins, that the Cu one would perform better...
Old September 27, 2008, 07:15 PM
Alwaysrun's Avatar
Interesting read at that link S_G thanks. My thinking now is that the overall cooling benefits of an all copper HS wins out over Copper/Aluminum because the overall mass of the copper can sap and hold it internally. My train of thought is who cares if it can radiate the heat as long as it gets it away from the CPU.
Anyways this debate looks like it's been going on for a long time now and I've decided not to pursue a career in thermal dynamics anytime soon. Maybe Thermalright will release a "True Silver" variation at a later date and the thermal property discussion can be reinvigorated. *omg did I just make a WoW reference there.. just shoot me
Old October 1, 2008, 09:09 PM
Eagle Eye's Avatar
Thermal Management | Power Electronics Technology Article Archives - thermal management, fans, heatpipes, thermal management
I did some reading this website their thermal management section has some interesting articles and it makes for a good read. Its also explores some new applications used in the electrical industry that we just might see used in computer later on in the future.
EE
Old October 1, 2008, 10:16 PM
S_G's Avatar
S_G S_G is offline
Forgive the pun, but that's pretty cool, EE. Going to read some more tomorrow, when I have more time.
