-   -   PC power and cooling silencer 610W (http://www.hardwarecanucks.com/forum/power-supplies/9514-pc-power-cooling-silencer-610w.html)
Dar_ell August 20, 2008 09:39 PM
Hey , i just want to know since the PC power and cooling silencer 610W is kinda longer (or was it bigger i don't really remember) would it have any problem fitting into a CM690 or an Antec P182?
NyteOwl August 20, 2008 10:56 PM
I have a Silencer 750 in a P182. You have to watch the cables don't touch the fan blades if you have the fan mounted in the lower compartment but it fits just fine so the 610 shouldn't be a problem. I removed the tricool from the lower compartment and mounted a Scythe directly to the metal divider with soft mount grommets rather than use the plastic frame which also gave me a little bit more room. No idea on the CM690 but I would think it will likely fit there as well.
1Tanker August 21, 2008 03:10 AM
I have a CM690. My PSU is a Corsair VX550. I compared the specs of mine and the 610. They're both the same width and height...the 610 is 1.6 in.(40mm) longer(180mm L vs. 140mm L). Mine fits easily with lots of room to spare, so you'll be okay with the 610 in a CM690. GL:thumb:
Dar_ell August 21, 2008 07:23 AM
oh awesome, i was worried thanks for your help guys :thumb:
