Old July 29, 2008, 10:06 AM
Default Enermax Pro 82+
So I'm thinking about getting this for my build
Specs
E8400
P5Q Deluxe
2 seagate 7200.11 320gb
pioneer sata dvd drive
Netgear wireless card PCI
7 case fans
4gb ddr2 ocz reaper x Pc2 8000
logitech x140 speakers
plus all the usual peripherals
Would an 625w enermax pro 82+ do the job?
Old July 29, 2008, 10:21 AM
why not go with a Corsair HX620 or a TX650?
Old July 29, 2008, 10:54 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Yup, it will do the job fine.
Old July 29, 2008, 11:01 AM
I've just remembered, I forgot to put the video card in, its a 4870. It uses something like 294 watts at peak watts.
Old July 29, 2008, 11:29 AM
misterd's Avatar
Still fine, they're nice power supplies.
| i7 920 / Noctua NH-U12P / Asus Rampage 2 Extreme / 24GB Corsair Vengeance / Asus HD5870 / Corsair 600T / Corsair HX850 / Intel 520 240GB |
| X2 5000+ BE / Passive Scythe Ninja Mini / Gigabyte MA78GM-S2H
/ 4GB G.Skill Pi / Fractal Core 3000 / Corsair CX430-M / Intel X25-M 80GB |
| i7 2700k / CM 212+ / Asus P8Z68 Pro-M / 8GB Corsair Vengeance / Antec SLK3700AMB / Seasonic M12-II 430W / Samsung 1TB |
#hardwarecanucks on irc.freenode.net
fiat justitia ruat caelum
Old July 29, 2008, 11:36 PM
Jackquelegs's Avatar
I'm using one right now, Uber good PSU.
Old July 30, 2008, 02:26 AM
Would I have enough watts left to upgrade in the future?
What are your specs?
Old July 31, 2008, 12:29 AM
At the moment:
Q6600 OC 3.0ghz Vcore 1.30V
OCZ Vista upgrade DDR2-800 5-5-5-15 2x2gb
Asus Maximus Formula
8800 GTX ACS3 (will change into 4870x2 or CF 4870 next month)
Enermax Pro82+ 625W
4x Scythe Ultra kaze 3000rpm
2x Harddrive
Old July 31, 2008, 05:53 AM
misterd's Avatar
I went to eXtreme Power Supply Calculator Lite v2.5 and took the specs in your sig assuming you have 2 SATA hard drives and 1 optical drive & 3 random USB devices that pull power. It says you need 380w even with your q6600 oc'ed to 3ghz. With the video card upgraded to the power hungry GTX 280 it says 426w, in SLI 576w. 2 4870's in Crossfire was 515w and the 4870x2 wasn't listed.
A lot of people fall into the marketing hype of bigger is better - especially when it comes to power supplies. My advise to anyone - Choose a quality one for your needs with some breathing room. Everything is listed at max. load and you would have to be stressing ALL your components to the max to ever hit that. Video cards are listed with high requirements so they can cover their asses. Your enermax will do you for a while in my opinion.
Old July 31, 2008, 11:41 AM
Talking
Awesome, on the extreme psu calculator I got 329w. Yeah so I guess I'm ok. Ordering tonight(probably morning in Canada???) Finally
God Bless Canada
