Old July 13, 2008, 07:40 PM
no_pulse's Avatar
Default This might be a stupid question....
A PSU will not turn on unless its connected to the motherboard correct? I had a very old 480watt PSU lying around and I wanted to test some fans. So I plugged in the PSU and hooked up some fans, and I didn't get any power. Can you damage a PSU just by plugging it into the wall and turning it on without hooking it up to the motherboard?
Ya I know, dumb questions.... :P
Old July 13, 2008, 07:50 PM
Infiniti's Avatar
No, you can't damage it. It is possible to turn on a PSU without a mobo. You should have a look on this page: Tutorials | Turn on PSU without motherboard - the 'paperclip trick' - APH Networks
You should really google things up first.
Old July 13, 2008, 08:00 PM
no_pulse's Avatar
Thank you very much :) And yes, I should have googled it first
