Old July 19, 2008, 11:58 PM
Level up: 20% Level up: 20% Level up: 20%
Level: 9 - 189 points to level up
Originally Posted by ChuckleBrother View Post
So as the title suggests, I am looking for a new psu that I intend to buy within the next 1-2 months, figured I may as well get my research going early.
I'm looking for something to power my system(listed below), the only difference being that I intend to get some CF cards. I really really want it to be modular, and have plenty of headroom for system upgrades.
I've been seriously looking at the Corsair HX1000, but I'm not sure if theres another company who offers good quality products. Is FSP any good, or Enermax?
Any recommendations are welcome, oh and my budget is sub $300 before tax, lower is better.
Well, NCIX heard ya man...http://www.ncix.com/products/index.p...7&promoid=1046
Lapped Intel Qx6850 @ 3.7 Ghz @ 1.4 volts
Coolit freezone elite
Asus Rampage Formula
8 Gig Gskill pc2 8000 4x2gig
HIS HD4870X2
BenQ V2400W monitor
Pc power and cooling quad 750
Old October 14, 2008, 04:50 PM
Level up: 23% Level up: 23% Level up: 23%
Level: 10 - 216 points to level up
Well, it appears my Tagan has crapped out. I have been experiencing a few glitches for the last week or so. Over the last few weeks, my apartment has been experiencing power flickers and power losses due to "building upgrades". During the last unannounced power outage, my pc refused to power back up. It did power up after about half an hour or so. Just yesterday I powered it down for the night and today it will not power up at all. The green mb LED used to be quite bright but now is now a little bit dull with a very slight flicker. PSU is also making a very faint buzzing noise but will not power up. I was getting momentary response from my ram cooler when hitting the power button, but nothing at all now.
I am now looking for a new power supply. The specs are in my sig except for 2 dvd drives. Also note that I require the PSU to be future-proofed for SLI (future video cards), an additional RAID array (0+1) and GPU-CPU coolers.
I am looking for a reputable psu brand with a budget of between $120-$200 before taxes. Any suggestions?
Thanks...
Asus P5N32 SLI SE Deluxe|Antec TPQ 850 |E6400|2GB OCZ 6400|Asus 8800 GT Top|2x 80GB SATA Seagate raid0|SB Audigy2 ZS|XP PRO|Dell 22" widescreen|Chenming 601-AE|Freezone TEC
Old October 14, 2008, 06:01 PM
MpG's Avatar
MpG MpG is offline
Level up: 62% Level up: 62% Level up: 62%
Level: 15 - 248 points to level up
You can start a new thread you know...
At any rate, I'd suggest the Corsair 750TX. It's got the necessary plugs, the necessary power output, is well-built, and is one of the quietest power supplies in its range. And it can usually be found in the middle of your price-range.
QX9650 @ 4.038GHz (425x9.5) | Asus Formula Maximus | GTX280 (777/1620/1404) | Mushkin XP2-8000 Redline 2x2GB
Q6600 @ 3.6GHz (400x9) | MSI P35 Platinum | 8800GTS 640MB (700/900) | Mushkin EM2-6400 2x2GB
Old October 14, 2008, 06:50 PM
WolfBane's Avatar
Level up: 53% Level up: 53% Level up: 53%
Level: 11 - 161 points to level up
Im running a antec 850 modular and it seems to be doing fantastic for what i am running :)
Old October 14, 2008, 09:13 PM
Level: 9 - 188 points to level up
PC Power Silencer PSU's are nice and solid, as well as running on the quiet side.
GAMING RIG:
Intel E8400 45nm Wolfdale Core 2 Duo @ 3GHz 1333MHz FSB w/ OCZ Vendetta II
4GB DDR 2 800MHz (OCZ Platinum)
Main: 160GB SATAII (Seagate) Storage: 500GB SATAII (WD)
Radeon Sapphire HD4850
610W PC Power Silencer
Asus P5Q SE
Old October 14, 2008, 11:33 PM
burebista's Avatar
Level up: 94% Level up: 94% Level up: 94%
Level: 9 - 15 points to level up
+1 for Corsair TX750.
You can take a look at BFG ES-800 too. Or if you want a PSU server grade Etasis 750.
Old October 15, 2008, 02:44 PM
Thanks for all your help. I have found a fantastic deal on an Antec 850 true power quattro at a local retailer for $148 taxes included. I like the semi-modular cabling.
Old October 15, 2008, 03:39 PM
WolfBane's Avatar
As do i mo let us know how you like it after a while:)
  #19 (permalink)
Old October 17, 2008, 07:26 PM
The TPQ 850 fits the bill. I fired it up for the first time last night with the coolit freezone installed that I recently purchased. Time to ramp it up! Thanks again for all your suggestions.
