Originally Posted by no_pulse So you think I will be fine using the 4pin to 6pin and the 6pin to 8pin connectors? The thing I'm worried about is it being powered properly. If I use the supplementary power connectors, will it have the same power? |
From what I've read the 6pin PCI-e connector supplies up to 75W guaranteed, while the true 8pin connector on newer PSUs pumps about 145W guaranteed. Having said that I've also seen statements that the 6pin connector can supply more than the guaranteed 74W, in fact up to 115W or so. Your mileage may vary of course.
I am not sure how the power output of the 4pin vs 6pin stacks up, so I don't know if that's a factor in your case.
Some 280GTX cards come with the 6pin-to-8pin adaptor (BFG does if I am not mistaken), some (like my XFX) don't. In fact, my manual states that the XFX 280GTX does not support the 6pin-to-8pin adaptor and its use is not recommended.
So I guess you could do two things - either try the 280 with the adaptor thingie and see if your PSU can supply enough power, especially if you're running the card under a heavy load (like Furmark for example) or sell your PSU and get a newer one that has 8-pin PCI-e connectors.
