Old June 23, 2008, 06:01 PM
Mulder's Avatar
Default Silverstone Zeus 750W
Does anyone know anything about this PSU? I need a new psu for a quadcore system, hopefully something that will last me a few years.
Silverstone Zeus ST75ZF 750W ATX12V 24PIN Power Supply W/80MM Fan Active PFC Quad SLI Certified - DirectCanada
Old June 23, 2008, 09:14 PM
The Zeus line has awesome build quality, not modular though, and you may want to verify that new revs included 8-pin pcie connectors.
I've got the 750watt model powering my current system, I haven't had any problems with it, so I don't have much of note to say about it.
Old June 24, 2008, 05:00 AM
Mulder's Avatar
http://img.directcanada.com/images/S...-ST75ZF_ca.jpg
Eight pin PCIE connectors? I thought PCIE connectors were six pin? Will I be able to use that to power a 8800GT?
Old June 24, 2008, 06:26 AM
Some new cards take an 8-pin connector as well as a 6-pin (9800 GTX, 9800 GX2 and GTX280 for nvidia).
The Zeus model has had a few revisions, with updated wiring, and with the wires swapped around to different rails, if you want specifics about the model they have in stock now, I'd contact directcanada/ncix directly.
Old June 24, 2008, 12:01 PM
JD JD is offline
Why not the Corsair TX 750W? That's the best 750W PSU out there to my knowledge...
Old June 24, 2008, 01:41 PM
Mulder's Avatar
I have a Corsair TX 750W on order and it's not going to be in stock for a few weeks,so I thought seeing how I haven't had my main rig up and running for closing on two months now I'd just go with this PSU.
Whats up with these pci connectors the 8 pin one will still run a 8800gt card right?
Old June 24, 2008, 02:27 PM
ipaine's Avatar
The 8 pin connectors are for some of the larger more power hungry cards, like the GTX 280, which uses one 6 pin and one 8 pin. The 8800 GT's only use the 6 pin connectors, which according to the picture you have 2, I believe.
"Nothing sucks more than that moment during an argument when you realize you're wrong."
zlojack's Avatar
My Zeus is 100% modular, but I don't know if that applies to all models in the line.
Old June 24, 2008, 03:22 PM
Mulder's Avatar
Anyone have any other opinions on any good psu's in the price range $100 -$150
what about these two PSU's
Coolermaster Real Power 750W
http://www.ncix.com/products/index.p...e=COOLERMASTER
PC Cooling and Silencer 750 Quad
http://www.ncix.com/products/index.p...%20&%20Cooling
Old June 24, 2008, 04:04 PM
SugarJ's Avatar
The PC Power & Cooling Silencer 750 is a great PSU, but unfortunately not modular. Depends what you want.
