Old October 29, 2017, 09:25 AM
Default DELL psu connections
Hey guys, so my dell xps 700 psu is on the fritz. Constant random restarts..
Anyway I have a brand new corsair psu lying around but of course DELL has to add a second 20 pin connection.
The 24pin on the corsair matches...
My question is, would it be possible to cut off the wire from the dell psu 20pin connection and some how jerry rig it to the corsair psu?
Im guessing no, not safe and so on but who knows..
Just i dont want to scrap the entire rig just because of a lousy psu, I was hoping on giving the pc to my mother inlaw for basic web surfing use..
I wonder if its worth buying the "new" dell xps 700 psu's I see on ebay for 100$... or just let this otherwise completely functional pc die
Old October 29, 2017, 11:02 PM
How about this one?https://www.ebay.com/itm/Dell-XPS-70...8AAOSw4GVYJNCk
Cheap enough to not be worth hacking up your new Corsair maybe.
Old October 30, 2017, 06:14 AM
Yeah, I was thinking i could maybe create some sort of adaptor that i could plug into a few molex connectors or something..
Im not sure I want to buy a used one though, Risky no? Esspecially from a machine that came out 11years ago?
Old October 30, 2017, 07:27 AM
You could do that. Just verify the pin out of that extra 20 pin and be careful with your connections.
I'm not familiar with that unit. What is with the extra 20 pin?
Old October 30, 2017, 08:17 AM
sswilson's Avatar
It's probably a throwback to the bad old days of Dell using proprietary pin-outs on their PSUs.
As far as the OP goes... what hardware are we talking here? Chances are you'd be just as well served to replace the motherboard with a non-proprietary one.
Old October 30, 2017, 09:58 AM
That's what I was thinking and that means verifying the pin-out of the 24 pin also. The OP already has the Corsair, so cobbling an adapter would probably be cheapest if a slight pain.
Old October 30, 2017, 05:00 PM
MARSTG's Avatar
I think there are some adapters on Aliexpress. Hardware wise XPS 700 is Core Duo Extreme 8600 and 7900 GTX SLI, with DDR2, so really old tech.
Old October 31, 2017, 09:51 AM
Yes we are talking some real old tech, I could get a cheap 775 mobo, but all the fans are proprietary as well
Plus I would have to mod the case to fit a non BTX board...
What do i have to do , verify the voltage of each wire?
If I cant make my own, what am I looking for adapter wise?
Thanks for the replies guys !
Old October 31, 2017, 09:56 AM
Throw up some pictures
Old October 31, 2017, 10:10 AM
Actually, the new 775mobos are roughly the same price as the new dell psu So I wont go the motherboard swap route..
I found this thread, Its kinda exactly but the reverse of what I need to do ( with pics )
https://forums.anandtech.com/threads...rsion.2293137/
PWM Y cable connections rfielder Water Cooling 1 November 12, 2013 08:05 AM
Need help to find connections Griezz Video Cards 5 August 19, 2012 08:44 PM
Legacy Connections _dangtx_ Off Topic 8 July 13, 2011 03:34 AM
HELP Fan connections with CM932 case? johndh New Builds 3 December 15, 2009 09:49 PM
680i sata connections Unklmo Troubleshooting 6 August 2, 2007 09:25 PM
