Old May 31, 2008, 11:49 AM
elninio's Avatar
Default 750 watt for under 50$ ? Required for idiotic idea
Note: purely experimental, might be a bit of lulz in there too. I will be testing some algorithms, custom waterblocks and watercooling loop
I'm going to overclock 2 quads G0 to 4ghz on water (success not guaranteed) on two different setups. GTX360 supersaturated with fans, providing cooling for the CPUs only. I may decide to stick the rad in a minifridge when I move back on campus, provided expected OC doesn't occur. Video cards will be minimal. Ram will be maximal, but not cooled on water. DDR2 expected for cost savings, unless I DDR3 really drops in price.
Its going to be a protein folding unit. Its going to be two mobos in one case. By how much would wattage vary if I were to purchase a serverboard (dual CPU) with 8 or 16 DIMM slots and populated it similarly to two separate single mobos.
My last desktop had a 600watt I got for 25$ , is there 750 watt for under 50$? If not what is the cheapest after that. When I bought my current case it came with a 550W, i opted to save 10 bucks by refusing to take it (well I would never have gotten to use it, and it would take too much effort to sell it). I will of course make adjustments to the whole system to avert a meltdown.
Yes. Yes, I am delusional and maniacal. I will be accepting premature epitaphs for this PSU in question...
Old May 31, 2008, 12:03 PM
a 650w for 25 is a very bad idea. ill pretty much guarantee its a bad psu and will probably take parts when it goes. any pc parts in a mini fridge will kill it. you cab get QUALITY psu's for cheap that will run a q6600
Old May 31, 2008, 12:13 PM
vinister's Avatar
Agreed its kind of like looking for the cheapest source of blood for your transfusion... not the best place to skimp for high OCs. You need to purchase way more watts than you think you need, so that your parts have maximal headroom to deal with current spikes, etc.
Mobo: DFI 790X-M2R
Proc: AMD PHENOM X3 720
Ram: OCZ Platinum 2X 2GB @ 1066
VIDEO: 3 x Visiontek HD3870
Old May 31, 2008, 12:52 PM
Cptn Vortex's Avatar
Also server boards are not designed for Overclocks.
The Vortex H20
Asus X99-E WS/USB 3.0
i7-5820K
3 x GTX 1070
4x4GB Corsair LPX 2666MHZ
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old May 31, 2008, 07:51 PM
elninio's Avatar
just tell me where I can get one
Old May 31, 2008, 07:52 PM
if you ask for advice, my advice is to take it.
Old May 31, 2008, 09:05 PM
elninio's Avatar
No, I've asked for answers to my specific questions, but you're advice is appreciated. I've considered it before, sorry I did not mention this. The only way I can afford to get this done is by cutting corners. I am willing to take this risk. The generic powersupplies that I've used in the past have have had loose molex pins which have caused sparks. I will inspect the unit before running it.
Would you also happen to know where I may get cable sleeving in the Toronto area? Thanks in advance.
Old May 31, 2008, 09:38 PM
yycraven's Avatar
my advice is spend the extra money and get a good PSU like this one
http://www.ncix.com/products/index.p...acture=CORSAIR
or this one
http://www.ncix.com/products/index.p...Z%20Technology
Old May 31, 2008, 10:17 PM
elninio's Avatar
or this one
You're right, those are good. But then I would need to get something like 900+ watt if I were to do things 'right'. Antec quattro looks really good, and its energy efficient too..Ah sucks to be poor..
Old June 1, 2008, 05:40 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
You could probably get a 750W for a few bucks at Tigerdirect but make sure to take pictures of the fireball.
