Old May 18, 2017, 06:10 PM
sswilson's Avatar
Default reputable UPS replacement batteries?
Looking to replace a matched set of sealed Lead Acid batteries on an EATON UPS.... any strong suggestions from folks in the know, or should I just head down to the local Battery Depot to see what they've got?
Dell Optiplex 3020 / Intel Core i3 i3-4160 / EVGA GT 1030 SC (Half Height) / 2 X 4GB DDR3 (Mixed) / Samsung 850 EVO 500GB SSD/ 24" Westinghouse L2410NM
Old May 18, 2017, 06:30 PM
sswilson's Avatar
Second question.... if the unit I'm replacing them in is 1000VA/600W would it make a difference to the unit if I replace them with a 1500VA set? It's still 2 12V batteries in series.... can't personally see what difference it would make.....
Old May 18, 2017, 06:37 PM
Sagath's Avatar
Matters not.
Get whatever is the same voltage and (physical) size. If its higher VA it just means a longer run time.
Old May 18, 2017, 07:30 PM
sswilson's Avatar
I don't suppose anybody out there knows for sure if the Eaton 5110 1500VA batteries are the same dimensions as the 1000VA ones? According to this 9 http://powerquality.eaton.com/LA/EN/...-am.asp?cx=120 ) the physical dimensions of the unit itself are the same.....
Old May 19, 2017, 01:01 PM
sswilson's Avatar
Local shop wants $36 / unit for a 7A battery and $52 / unit for a 9A one. I can get a pair of 8A ones through amazon.ca for $51 + $10 shipping which still comes in less expensive than the 7A ones locally. (All the 12V ones appear to be the same dimensions).
https://www.amazon.ca/Pack-POWERWARE...ry+replacement
Old May 19, 2017, 03:32 PM
KaptCrunch's Avatar
SS I think its 24volt ups unit for 2 12volt batteries are in series
the 7a to 9a means more capacity of run time
if you want can use a boat AGM battery and double the run time but it wont fit UPS case
try your local industrial battery rebuilder an cut out the middle man
Old May 19, 2017, 04:47 PM
sswilson's Avatar
Do people rebuild SLABs?
On that note.... there's one other place to check out locally (I think it's an Interstate affiliated store) but I have my doubts that there's an accessible battery rebuilder locally.
Old May 20, 2017, 08:16 AM
KaptCrunch's Avatar
try 1400 Mountain Rd, Moncton NB
Old May 20, 2017, 08:39 AM
sswilson's Avatar
That was the $36 / $51 location.
Old May 27, 2017, 06:38 AM
So how did you do with this? In my locale it is difficult to find these batteries at all, let alone, for a decent price.
How about the quality of replacement laptop batteries FrankQin Power Supplies 1 September 12, 2016 03:06 AM
Need a reputable place to buy a laptop battery Nodscene Off Topic 9 February 1, 2012 04:13 PM
LF: reputable computer repair shop cmge Troubleshooting 8 August 3, 2011 08:02 PM
Reputable Site for Laptop Batteries geokilla Mobile Computing 5 August 29, 2010 03:39 PM
replacement laptop batteries dheian Mobile Computing 5 January 13, 2008 03:55 AM
