Old May 18, 2008, 04:59 AM
Default 90 degree elbow clips??
I never understood why no one desgined a cable for the GPu's that have a 90 degree eldow to better hook up the power cables to the cards. If u think about what I am saying.... for those cards like mine that connect on the side facing the door, the cables basically have to bend out and around in order to hit the plug head on. If there was a 90 degree plug (like some of the sata cables peeps use for Hard drives) the cable would run striaght up the side of the card then plug in..... even a "U"" shaped clip would work well.U know what im tryin to say?
i2600k sandy bridge @ 3.4ghz/ 2x 8800 GTX KO ACS3 PCI-E 630MHZ 768MB 2.0GHZ SLI'd / Raptor 74GB / Antec 1200 Hundred Gaming Case / G.Skill Ripjaws ddr3 1600 cl 8-8-8-24 - 8gigs / evga z68 SLI MOBO / Samsung DVD+RW / Corsair ax850 PSU / 24" Samsung CinkMaster
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Swiftech Apogee GT Cpu block
Feser One Red Fluid
Old May 18, 2008, 07:25 AM
magictorch's Avatar
Default yes i do
oh yes-it would look much cleaner with the right cable management.
Ideas like that can make people a lot of money.
