Old June 3, 2014, 01:46 PM
Default good budget psu?
A PSU seems to have died on this computer (not mine). Well, the main fan won't spin. Computer starts up eventually though. Eventually, it shuts down. I am thinking it's the psu that is the culprit. Thoughts? :)
It's an old generic PSU and I'm not sure how old (how many yrs). It's not 80 anything.
Is there any moderately priced ones that would be a good replacement? I'm saying that because I'm not 100% sure the PSU is the only problem but I'm relatively sure. Also, it's an older system... Sempron CPU. DDR2 RAM etc. I guess any new psu can go into a new system but I am hoping the mobo is okay. I'm looking at a cheap passive gpu, too. HD Radeon 6450 any good? No gaming is done on this computer.
Therefore, 400W is probably sufficient but it can be more. I was wondering if I should look for modular. Doesn't have to be, though, right?
Old June 3, 2014, 02:42 PM
Bond007's Avatar
Here are a couple quality ones that aren't expensive.
http://www.ncix.com/detail/seasonic-...30144-1374.htm
http://www.ncix.com/detail/antec-bas...62331-1360.htm
EDIT: Sometimes you can get decent ones on sale for $20-25 after MIR if you aren't in a rush, but thats the best I see right now with a quick look.
Desktop: Arc Midi R2, Z77-D3H, 3570K 1.09v/4.1ghz with Zalman Optima Cooler, Corsair Vengeance [email protected], XFX R9 280X DD, Bitfenix Fury 750w, WD Black 1TB, Intel 530 120GB
Old June 3, 2014, 04:56 PM
TTC TTC is offline
Where are you located? Maybe you can borrow one
Old June 3, 2014, 05:12 PM
Disconnect it and don't use it. If its a generic POS, its probably dead. Don't kill the mobo, by using bad power. Then you'll need a new system. If your good with a multi-meter and now how to short out a psu to run?.....still won't be under load. Probably pushing 10 volts. Throw it out.
Could also be a failing cap on the mobo, but since the fan isn't spinning on the PSU? Probably a failed cap on the PSU. (Got To Hot)
Old June 10, 2014, 07:21 AM
Everyone seems to like the Corsair CX430 which runs about $50 but can be had with fairly regular MIRs for about $30 (taxes not included).
If you're really going budget or need something in a rush I think I have a few Enermax NANX 450W I got for $35 a pop that I used to use for cheap PC builds.
Old June 17, 2014, 04:42 PM
I second the CX430, run one in my HTPC and its been great!
Old June 29, 2014, 05:57 AM
MARSTG's Avatar
I am running an Antec Earth Watts Green 380 for years now without issue. Actually it was able to drive a system with a GTX460 and a Phenom II X4.
Old June 30, 2014, 12:25 PM
I hope it's the psu. Was troubleshooting two systems with similar specs/gen. hardware (both AM2/AM2+) and one Antec 350W and one Seasonic 400W (Tornado) - both have quit around the same time and had similar symptoms. Both are 20-pin so they're old. Hope, I didn't wreck anything else. :) I think both power supplies are done like dinner - probably should have bit the lip and bought a new psu to test?
If either or both systems are still okay minus a defective psu each, then I'll probably re-visit the thread and see what is out there at that time.
Old July 5, 2014, 08:49 PM
A Corsair CX430 would be good to replace that one. Don't buy another cheap POS.
Whats a good budget SSD Drive? Blu Storage 12 December 16, 2010 12:05 AM
A good budget bang-for-your-buck card? andynerd Video Cards 24 December 5, 2010 04:11 PM
Intel Destop PC CPU price cuts! Good news for new budget builders :) Silvgearx Press Releases & Tech News 13 April 3, 2009 06:04 AM
ATi to launch RV790? Good news for budget gamers. Silvgearx Press Releases & Tech News 20 December 4, 2008 05:02 PM
