Old April 16, 2014, 08:53 AM
ShinraCorp's Avatar
Default Is my PSU Hashwell compatible?
So I'm looking to upgrade my mobo, CPU and RAM this summer to the latest Hashwell (or Devil Canyon depending on when they're out) I'm keeping the case, the GPU, the HDDs, the ODD and the SSD, however I may keep the PSU if I know it works with Hashwell.
I keep seeing these Hashwell certified PSUs so I'm wondering if it's such a big deal.
My PSU is a XFX XPS Black Edition 750W dated back in 2009 so I'm not sure if it'll work or not, if it does then it saves me a PSU during the upgrade.
Thank you
Old April 16, 2014, 08:59 AM
sswilson's Avatar
I stand to be corrected, but I haven't seen anything to suggest that it's not just marketing hype.
Old April 16, 2014, 10:16 AM
The Buzz Kill's Avatar
you should be fine.
Old April 16, 2014, 10:50 AM
Bond007's Avatar
You will be fine. I think I have only heard of one case where someone had an issue and it just involved turning the lowest power state off to fix.
Old April 16, 2014, 07:22 PM
ShinraCorp's Avatar
Alright thanks guys. Hopefully it'll work for me.
Old April 18, 2014, 06:06 AM
MARSTG's Avatar
It is mostly marketing hype, Haswell generation requires a spec on the PSU to reach the lowest power state, but nobody here building a game system thinks at that, so you are just fine.
Old April 20, 2014, 08:37 PM
Shadowarez's Avatar
So Haswell doesn't need a eps capable psu?
Old April 21, 2014, 05:43 AM
JD JD is offline
Depends on the motherboard, but I think you'd only need EPS on a LGA2011 platform where there is dual 8pin (or 8+4) CPU power connectors.
Old April 22, 2014, 03:09 AM
Shadowarez's Avatar
Hmm I dont use the eps connector on my Rive be was told by evga when I was powering system for first time. Should I be using the eps power as well? Sorry for jacking your thread.
Old April 22, 2014, 05:37 AM
ShinraCorp's Avatar
It's all good I got my answer so I don't mind if you did.
Will all of this be compatible? ShadowRocks New Builds 23 February 15, 2013 01:39 PM
Ram Compatible With Sabertooth Z77? PcWizTech New Builds 3 July 19, 2012 10:28 PM
RAID compatible HDD moocow Storage 9 January 5, 2012 01:51 AM
Compatible? Deano85 CPU's and Motherboards 2 November 19, 2011 08:49 AM
Ram compatible with this motherboard? Modus RAM 7 August 26, 2010 06:08 PM
