Old March 28, 2014, 04:25 AM
Default Seasonic fanless 520
Well I blown my evga psu. My fault but I am wondering would this be enough? My system Amd 960T, asus 7970 dcii, d5 pump, 6 gentle typhoon + 1 genaric fan. 2X adata xg900 128 ssd. I wiil be overclocking the system. I figure 125 watts cpu, 300 watts gpu which only leaves with 95 watts for my water pump.
Old March 28, 2014, 07:19 AM
MAC's Avatar
MAC MAC is offline
Associate Review Editor
You should be fine, just don't go crazy with the CPU overclocking.
Oh, and consider buying a P3 Kill a Watt one of these days, will give you some peace of mind when it comes to questions like these
Old March 28, 2014, 07:34 AM
Bond007's Avatar
It will be enough, but as you said no extra room available. Personally with that setup I would run a 600-650w PSU for long term use. I wouldn't plan on using more than 75-80% of rated capacity if you want it for the long haul (ie you don't want to have to deal with blown PSU every now and then).
Fanless watercooling? mattydies Water Cooling 17 January 3, 2013 04:24 AM
Fanless Spinning CPU Heatsink LaughingCrow Reviews & Articles from the Web 12 July 14, 2011 12:21 PM
[FS] 4890 1Gb w/ fanless AC & optional fanpack n-sanity Buy/Sell & Trade 5 October 5, 2010 08:56 PM
low heat emission power supply (fanless?) elninio Power Supplies 17 March 6, 2008 09:26 AM
Possible to make a fanless rig with heatpipes and hs? Il Duce Overclocking, Tweaking and Benchmarking 5 December 22, 2007 04:48 PM
