Old February 4, 2014, 03:49 AM
Default Seasonic X-750 or Corsair AX760?
Which have more reliability and less problems of coil whine and DOA? and about the RMA which brand have better support and lower shipping costs from EU?
Thanks.
Old February 4, 2014, 09:37 AM
These are actually the exact same PSU internally, the only difference is corsair's warranty is longer so i would go with them.
Old February 4, 2014, 04:41 PM
Corsair RM series, XFX 650-850 XXX/Core, EVGA supernova and the new SilverStone Strider Gold S ST85F-GS 850W.
Old February 12, 2014, 10:48 AM
sweenytodd's Avatar
Get and XFX 750W Black Edition. Its a rebranded Seasonic X750 and somewhat lower price.
Old February 19, 2014, 09:04 PM
sa seba's Avatar
As JJThomp already said, the Corsair AX760 has the longer warranty, and on top of that, all cables all fully sleeved in black, whereas the Seasonic displays a nice array of colours at the connectors.
Old May 6, 2014, 03:19 PM
Ashihtaka's Avatar
Just wondering why go for x750 and not x760? Did you consider the x760 (Seasonic)?
Old May 6, 2014, 03:44 PM
Caldezar's Avatar
The OP's question relates to the X750, not the X760. So they are actually different units. As feature differences, the AX760 has a switch on the modular side that allows switching between 'regular' and 'hybrid' fan modes for more silent operation AND the AX760 is platinum certified vs gold. Besides that, the major comparison will be price vs features/warranty. Personally, I like Corsair's support, and the extra details in build and features are worth the extra money to me. I'm always a fan of ensuring PSU is one of the best components of your system.
Regarding the Seasonic X760; although the Corsair is MADE by Seasonic, and uses mostly the same internal assembly parts as the X760, they are not the EXACT same units.
Old June 17, 2014, 04:40 PM
I have the Seasonic X750 gold, its the original of this design and doesnt skimp anywhere in parts spec, after doing some through digging both the corsair AX750 and XFX750Black use lower grade parts in places (caps not quite as big, higher impedance mosfets, cheaper fan in the XFX etc...) im sure they will all be good, but I wanted the piece of mind and like overbuilt. It also has the hybrid fan switch as the X760 does and the cables are all black too. Hardware Secrets does a great review on the unit and it will run overloaded as well up to almost 950w! Its a great powersupply for me and has not had a single issue for me.
Old July 6, 2014, 05:27 PM
I had no idea XFX rebranded Seasonic PSU. I have put a couple of XFX PSU in builds for friends. Good to know they are descent PSUs.
Old August 25, 2014, 06:03 AM
Not all XFX PSU's are rebranded Seasonic PSUs. I believe only the PRO series Black Edition and the new XTR Series are rebranded Seasonics.
Edit: Actually I may be incorrect about this, it does look like all XFX power supplies are supplied by Seasonic!
Corsair AX760 PCI-E cable design... av3n Power Supplies 4 June 4, 2013 11:12 PM
Will the Seasonic X-460 be enough? lsquare Power Supplies 7 October 25, 2011 01:51 PM
SeaSonic X-760 vs. Corsair AX-750 blinkdagger Power Supplies 9 July 11, 2011 10:20 AM
Corsair or Seasonic??? jcmaz Power Supplies 6 October 8, 2009 04:13 PM
