Old December 8, 2013, 10:46 AM
Lpfan4ever's Avatar
Default APC Back UPS XS1300 - "Battery Disconnected"
Wondering if there's any UPS gurus who might tell me if this is fixable or I'm SOL. I'm assuming it's hardware related as the UPS made a cross country trip and sat in storage for two months.
I finally moved into a new place and got my rig setup, only to have my UPS flash and beep at me to tell me that the battery isn't connected. After letting it run for a few hours it'll see the battery and charge it. Then after a few more it'll stop seeing it. I yanked the batteries and they're testing fine for voltage, and the terminals are seated well. I noticed that if I run the self test in PowerChute, the battery immediately "disconnects" and the test doesn't finish.
Time for a new UPS?
Originally Posted by encorp
Code:
<firebane> slightly used
Old December 8, 2013, 12:17 PM
Batteries have two types of voltages resting and load. The battery at resting may very well show the proper voltage and be ok but once you put a load onto it the battery will fail.
This exact situation happened with the battery in my truck.
Old December 8, 2013, 12:30 PM
Lpfan4ever's Avatar
I failed to mention too that the fan on the back of it likes to ramp up to 100% frequently throughout the day for a few minutes at a time.
Ena, you're suggesting new batteries in this case then?
Code:
Old December 8, 2013, 12:37 PM
Possibly.
Without throwing an external charger onto them to see what they charge up to and then see if they lose any votlage you'd really be guessing.
Old December 8, 2013, 12:42 PM
Lpfan4ever's Avatar
Well, when the batteries do decide to reconnect to the UPS they're never at 100%. Usually drops down to ~95% between the time it disconnects and then reconnects.
Code:
Old December 8, 2013, 01:07 PM
ipaine's Avatar
Chances are it is you battery that is toast. You can get new batteries direct from APC, although you might find them elsewhere. If I were you I would check out the support on APC's page. Support
"Nothing sucks more than that moment during an argument when you realize you're wrong."
Old December 8, 2013, 01:16 PM
KaptCrunch's Avatar
un-plug battery pack with no ac power try to start then re-plug battery pack to reset bat state.
AC power and let it (UPS) charge for a full day and not use/turned on but unit is powered in off state.
the batt light is saying
your batteries have met their end, time for new set
reason fans ramping is giving full charge, seems batt aren't taking full charge other wise ramping would stop
have tried to start UPS with out power cord in wall outlet, if dead no lights, fuse is blown on batt pak .
if handy with tools can use 2x 12v bats in series = 24v to test
gel cells are expensive and sealed for your safety, very costly upgrade to AGM from CTC $362 and x4 times the run time.
Note: if use lead/acid batts, need well-ventilated area for gases will effect health when charging and explosive if near open flame/spark.
question did it run its self test when turn on then the bat light is lit
indicates battery replacement for can't support the load
Old December 9, 2013, 10:20 AM
Soultribunal's Avatar
The Fan is going on because it is cycling into 'Charge Mode, and then Battery Mode' in which case you need the fan to cool the internal bits.
Those APC Battery packs can be expensive, but I have a battery guy who has usually a cheaper solution. I know, I have 3 x XS1300's at home :)
-ST
www.realhardwarereviews.com
Old December 10, 2013, 09:26 PM
Lpfan4ever's Avatar
Sooo, two days after the original post I had a battery charger lent to me (yay Ena) to check if it was really my batteries. Couldn't get them out of the enclosure, so I had to kinda force em out. That's when I saw this and NOPE'd the **** out and stuck the batteries outside. Safe to say, they're dead for sure.
Code:
Old December 11, 2013, 06:18 AM
Yeah those are dead, not sure if there are any local battery shops nearby.
If not I know I can get those fairly cheap.
-ST
"Dell 5521" vs "Acer V3-571G" vs "V3-571G SSD" N7pSTR New Builds 3 May 7, 2013 04:03 PM
"BF3.3" Level 10 GT Case Mod is "Locked and Loaded" Mnpctech Cases 2 July 12, 2012 12:18 PM
How do i know if my "Drive Controller" is running in "AHCI mode"? Teo3201 Storage 2 October 8, 2011 09:54 PM
[WTB] 2.5" IDE hard drive and battery punk_zappa Buy/Sell & Trade 1 August 25, 2011 10:18 PM
[FS] Acer Timeline 3810TZ - 13.3" CULV, 4gb RAM, 320gb HD, x4500MHD, 5~6 hour battery coriolis Buy/Sell & Trade 5 March 8, 2010 09:51 AM
