Old November 1, 2013, 07:00 PM
Default is the Corsair TX-650 any good?
Old November 1, 2013, 07:01 PM
also could you run 2 gtx 560ti in sli using that psu?
Old November 1, 2013, 07:15 PM
Birk's Avatar
Im using the 750 model. Runs everything. Crossfire 7970 3gb over clocked and 16gb and custom loop
Old November 1, 2013, 07:27 PM
And no problems?
Old November 1, 2013, 07:45 PM
Birk's Avatar
No issues at all. I am however thinking of upgrading to a bigger one just so I have a little more wiggle room as I'm about to go dual loop with 2 D5 and more fans and more gear...
Old November 1, 2013, 07:49 PM
sswilson's Avatar
I was running a heavily OC'd 1090t + SLI'd 560ti cards and I was popping the breaker on a 600W UPS so I'd recommend a 750W at the very least, and since I'm all about overhead I'd personally pick up an 850W instead. :)
Old November 1, 2013, 07:53 PM
Dzzope's Avatar
Decent psu but you'll be pushing it very hard under full load if it can take it (depends on what else your running with it).. Suggest 750 - 850w too for sli.
Random quotes:
AKG: "So please don't piss on people and claim its raining. "
Soullessone21: "Their the only fat bitches I ever want in my wife :)"
DeeraxTheCoolNemo: "I never preSs CaPLoCK I just HiT my keyS so Hard ThEY Crit"
Old November 2, 2013, 02:21 AM
they have an issue with the TX series that the PSU ticks like a hard drive when fan is not on
Old November 2, 2013, 08:40 AM
Thanks and was your breaker in your panel tripping? Is that what you meant?
Old November 2, 2013, 09:18 AM
sswilson's Avatar
No. The UPS has a safety feature that takes it offline if there is too much draw from connected devices so it's an internal "breaker" as opposed to something on my power panel, but the outcome is the same as it cuts power the same as a cct breaker would.
Corsair Carbide 500R: Good enough for TRIFIRE? Masteroderus Video Cards 6 May 4, 2012 04:10 PM
[WTB] a good router flashed to good firmware gingerbee Buy/Sell & Trade 9 February 15, 2012 06:15 AM
what is a good Media player for a good price or any suggestions Shadowmeph HTPC Systems & Software 4 December 19, 2009 11:27 PM
So about the Corsair Obsidian, any good strategies for setting up a loop in that? Z Overlord Water Cooling 7 September 21, 2009 08:20 PM
Is corsair PC2-5300 4GB 2X2GB DDR2-667 kit a good choice for dell XPS M-1730? Styll RAM 0 January 16, 2008 01:04 AM
