Old October 18, 2013, 04:20 PM
Dzzope's Avatar
Yea lovin my XFX 1000W Platinum (both seasonic based units) wonder why they don't have a higher rated unit than 1250w...
Random quotes:
AKG: "So please don't piss on people and claim its raining. "
Soullessone21: "Their the only fat bitches I ever want in my wife :)"
DeeraxTheCoolNemo: "I never preSs CaPLoCK I just HiT my keyS so Hard ThEY Crit"
Old October 19, 2013, 12:41 PM
rjbarker's Avatar
^Youll be extremely disappointed with the results of Quad SLi (very poor Scaling), checkout some if the Benchmark results showing the slightest improvements Tri SLi vs Quad SLi....in some cases Quad results in poorer performance that 3 Cards.
Firestrike Extreme: 21.452
MARK 11: 32.530
Old November 18, 2013, 09:31 PM
JohnWayne's Avatar
Indeed. Just because you can doesn't mean you should. Unless you were doing something like content creation where the scaling factor is known, 3 way SLI is more than sufficient for gaming. The 780 Ti TDP is only 250W. so a platinum 1kW PSU should be more than enough and still leave some room for tweaking.
As far as acoustics goes, wattage and noise aren't exactly linear, it's all in how the unit is engineered. My toaster is 1500W and it makes toast in perfect silence :)
Old November 24, 2013, 02:47 PM
Are we certain a supernova 1500 is enough for 4 titans. I am running 4 titans and my PC crashes the instant I turn on furmark. Well it doesn't crash , it restarts. I would really like to think it's caused by something else but all I can come up with is the psu.
I'm going to die if I have to buy a second psu.
Any help?
Old November 24, 2013, 07:12 PM
rjbarker's Avatar
^^^^^ Absolutely 1.5 kW (or even 1.2 kW) is enough for x4 Titans Quad SLi.....you've got PSU issues or Driver Issues if you're constantly crashing ;)
MARK 11: 32.530
Old November 24, 2013, 09:06 PM
fishingfanatic's Avatar
Smile Which Psu is Best?
I think in part it depends on the psu. My Corsair AX1200 might be able handle 4 titans, though ocing might be an issue.
Tri sli didn't get very warm or loud. My friend's Antec 1000 can only handle sli, and the Corsair handles tri.
The 1500 is good for both the adequate power and the correct number of pcie plugs. The aux. take up a spot on the AX 1200, and I didn't want to try running the mobo off of a molex, otherwise it might've been
able to handle quad sli/xfire, though not titans, at least I don't think so.
I did run a pr of 690s on a Corsair TX 850M with no problems though I wouldn't recommend it, as it got pretty warm. Still works fine.
FF
[FS] 775/AM2+/AM3+/FM1 board - Adding daily Rasparthe Buy/Sell & Trade 108 March 20, 2014 03:34 PM
I caved... Quad GTX 580 UD with new AC waterblocks.. New 990X and new 1500W PSU Phatboy69 Case Mods, Worklog & Gallery 141 December 7, 2011 10:47 AM
