Old October 2, 2013, 07:57 PM
rjbarker's Avatar
Default Additional PSU
Quick query guys.....if someone were to run an additional 2nd PSU, what does the 24 Pin connector look like that is required?
I think I saw what it looks like once, basically a 24 Pin Splitter one end plugging into the Mobo, the power supply connectors plugging into 2 ends.( like a Y Splitter), is this correct? (Or is a "jumper" all that is necessary)
If anyone can find a link to the required cable on NCIX, FrozenCPU etc...would be much appreciated.
Cheers
RJ
Firestrike Extreme: 21.452
MARK 11: 32.530
Old October 2, 2013, 08:09 PM
Easiest way is connect the green wires together and a black wire.
For more complex get a relay involved.
Old October 2, 2013, 08:48 PM
SugarJ's Avatar
Can't find one on NCIX, this one's on FrozenCPU. Lian Li Dual Power Supply Adapter Cable - FrozenCPU.com
They work, I used one in my TJ07 back when I was running SLI GTX285's. Basically the black wire ties the grounds together, and the green wire gives it the start signal from your motherboard / power switch.
Old October 2, 2013, 10:38 PM
KaptCrunch's Avatar
Default discalmier use at own risk
if handy with pliers use SCOTCHLOK QUICK SPLICE WIRE CONNECTORS TERMINALS TAP SCOTCH LOCK 18-14 GAUGE solderless connection
#15, 16 green and black join them to other PSU green & black
if wrong use will have loss of life or property damage
Old October 3, 2013, 01:04 PM
rjbarker's Avatar
^^^ Thanks Sugar, exactly what I was thinking about...cheers ;)
MARK 11: 32.530
LANified! 10: Additional Pylons Calgary Nov 4-5 2011 BloodyIron Canadian LAN Parties & Events 7 November 7, 2011 11:05 AM
Should I buy additional fans? MrDiaz Cases 27 April 8, 2010 06:25 PM
Additional cooling for CM 690 II Advanced mike.mgs4 Air Cooling 12 February 18, 2010 12:08 PM
TJ09 Case n Additional 120 mm Fans rjbarker Cases 1 November 11, 2008 11:04 AM
No Additional Crysis Patches Hardware Canucks Press Releases & Tech News 11 June 6, 2008 07:28 AM
