Old September 29, 2013, 12:45 PM
Default Best low watt PSU?
I'm lookin for a low wattage PSU to power just a AMD A10-5800k mobo and SSD. Can you guys suggest me something low watt that is high quality? Also the smaller the better but SFF is not a must.
Old September 29, 2013, 02:12 PM
Bond007's Avatar
Price range? Does looks matter?
Old September 29, 2013, 02:38 PM
Price don't really matter but the cheaper the better. Also Looks don't matter much but would prefer it to be quiet.
Old September 29, 2013, 05:17 PM
Check out the corsair CX430 for $30 at NCIX. I've used the modular version for an AMD A10 5800k HTPC build and it works great.
Never buy cheap no-name PSUs. Unless you LIKE fire hazards that can potentially burn down your home.
Old September 29, 2013, 05:53 PM
Bond007's Avatar
Haven't used it, but OEM seasonic 300w bronze. for $40+8 shipping, but then there is a $10 code until oct 3rd....makes it $38+tax including shipping.
Newegg.ca - SeaSonic SS-300ET Bronze 300W ATX12V V2.3 80 PLUS BRONZE Certified Active PFC Power Supply - Power Supplies
Should do the trick quite nicely...or do you need a smaller sized PSU?
Old September 29, 2013, 06:38 PM
That looks perfect and a great price. Thanks a bunch for the find!
Old September 30, 2013, 10:21 AM
Bond007's Avatar
No worries. I think that should be a great PSU, unless you plan on adding a mid to high end gpu at some point.
Old September 30, 2013, 11:41 AM
Soultribunal's Avatar
Not sure if you have purchased it yet, but a good SFF factor is the Silverstone 450W Gold unit. JG gave it a good review, and if you are mashing it into a mITX Case, I can't imagine a better unit for its size and cost.
Just a thought.
-ST
www.realhardwarereviews.com
Old September 30, 2013, 11:54 AM
lowfat's Avatar
The Silverstone is rather loud though. I bought one for an HTPC and couldn't use it because of the noise.
Mael
Big Lian Li
Forever Alone
gtx 650 ti on a 430 watt psu BurningAce705 Power Supplies 26 January 30, 2013 07:30 PM
Enough Watt? BFighter New Builds 5 April 21, 2011 03:49 PM
watt for two GTX 295 hohohee Video Cards 24 September 24, 2009 08:49 PM
i7 920 + 2x gtx 275 = 750 watt? MittWaffle Power Supplies 8 August 14, 2009 05:07 AM
Is a 750 watt PSU Enough? Rocco_360 New Builds 17 March 20, 2009 01:48 PM
