Old July 29, 2013, 09:21 AM
xxx xxx is offline
Default only 10.56 volt max on 12 volt rail.
only 10.56 volt max on 12 volt rail on my coolermaster extreme power plus 650 watt
using hwmonitor & speedfan
Old July 29, 2013, 09:25 AM
Software = useless.
You need to be using a multimeter to really know. And being a Coolermaster EXTREME that you are using.. I'd rather choke myself to death with it
Old July 29, 2013, 09:28 AM
Shadowmeph's Avatar
it is best to use actual hardware to test volts and the like like the red wires are so many volts and the yellow wire is so many volts ,I don't remember exactly off hand .
Now what you are reading is that is what is being used?
Old July 29, 2013, 09:39 AM
Soultribunal's Avatar
Software unless used in combination with HW is pointless for measuring the actual output of the Rail(s).
That being said , that particular PSU isn't the best one available in its range that's for sure.
-ST
www.realhardwarereviews.com
Old July 29, 2013, 12:24 PM
xxx xxx is offline
is this same with temperature measuring software
Old July 29, 2013, 01:30 PM
Not usually although Speedfan and HWMonitor can sometimes report incorrect temperatures (i.e. HW monitor reports my SB chip at 256 degrees).
That being said Coretemp and Afterburner (and programs like them) poll their information right from the source so they tend to be right on the money when it comes to monitoring.
-ST
Old July 29, 2013, 07:15 PM
KaptCrunch's Avatar
YEL = 12V
RED = 5V
Old July 29, 2013, 07:27 PM
sswilson's Avatar
The only thing I've ever used software PSU voltage monitoring for was to see if there was much of a difference between what was reported for load vrs idle.
Low 12V rail on Corsair AX1200 Prolab Power Supplies 6 August 6, 2011 06:58 PM
how to install 12 volt power switches for PC Overclocker~4.1 Troubleshooting 13 September 8, 2010 09:02 PM
8800 GT Bios Volt Mod How to ?? Dashock Overclocking, Tweaking and Benchmarking 3 September 3, 2008 09:00 AM
8800GTS volt-mods????? bushwickbill Video Cards 1 September 23, 2007 05:20 AM
-12v Rail and Poor Performance kcksteve Troubleshooting 11 September 9, 2007 08:08 PM
