-   -   Corsair PSU SATA Cable HELP! (http://www.hardwarecanucks.com/forum/power-supplies/62038-corsair-psu-sata-cable-help.html)
Bad Fenny July 7, 2013 06:15 AM
Hello,
I am currently creating a build and was in the process of sleeving my SATA cable. I had to reposition the connectors and when I did, two the wires broke. I don't have a spare SATA cable to replace for the PSU (Corsair 850AX), I do however have a Corsair TX750 SATA cable (same length).
This was what I wanted to do . . . I was going to transplant the TX750 to the AX850 PSU connector (ensuring I ran the TX750 wires in the same configuration as the AX850 to the new connector). My only concern is that while I can run the wires in the same configuration, will I still have an issue with the SATA connectors on the TX750 wires. Specifically, are all SATA connectors the same . . . so for example if I take a wire coming out the of TX750 SATA connector and run it to the same place on the PSU connector as it would for the AX850, will it still do what it is suppose to do? Sorry if this is confusing, not sure how to word it better :sad:
JD July 7, 2013 11:19 AM
All SATA connectors are wired the same, but the modular plugs on the PSU vary between Corsair's models. As such, the modular cables they provide specifically say to only use it with xxx PSU.
If you drop Corsair an email/open a ticket, they'll send you another SATA cable for free. They did for me at least.
KaptCrunch July 7, 2013 11:38 AM
JD is correct on PSU side so best use a voltmeter to verify voltage and polarity @ sata end
http://forum.dayton360mods.com/attac...7&d=1335951292
Bad Fenny July 7, 2013 12:00 PM
Thanks guys, will test the SATA end with a volt meter to verify.
Cheers
Fen
