Old June 17, 2013, 08:30 PM
addbot's Avatar
Default Quickest way to test a power supply?
I have a Corsair AX750W power supply I want to test out of the box, I wouldn't be able to try it out on my system till the weekends. But I would want to know if it is working right now. I have a Arc mini r2 right now with me w/3 fans and a speed controller. Can I connect the fans to test? Thanks
Old June 17, 2013, 09:10 PM
Shadowmeph's Avatar
If you mean to turn the PSU on just to see if it will run then yes but you need to jump the green and black wire I used a paper clip to do this this will turn the PSU on . but like I said it will only power on the PSU the proper way to actually test it would be with a volt meter
Old June 17, 2013, 09:49 PM
KaptCrunch's Avatar
when got your MB and PSU check the power connections before powering up so not to mix pci-e and MB power connections @ PSU
Old June 17, 2013, 10:29 PM
addbot's Avatar
oh yeah, the jumper
thanks for reminding, it does look the same.
Power supply surges detected during the previous power on. Asus Anti-Surge was trigge Varroa Power Supplies 7 December 18, 2012 06:50 AM
OCZ Technology Unveils the PC Power & Cooling Silencer Mk III Power Supply Series Sam_Reynolds Press Releases & Tech News 8 November 9, 2011 08:48 PM
PC Power & Cooling Unveils New 760W Silencer Power Supply FiXT Press Releases & Tech News 3 December 18, 2010 04:53 PM
