Old June 5, 2013, 08:41 AM
Default Molex to 12V DC Adapter
Anyone know where I can buy a Molex to 12V DC Adapter?
Like the one:
http://i.imgur.com/AXFXox7.jpg
I can't find them anywhere. I made one myself, but the DC wire I used was very low quality and parts of the positive and negative wires were touching, causing it to short out.
I want to use a proper one instead.
Old June 5, 2013, 09:34 AM
lowfat's Avatar
You pic doesn't work.
EDIT: I've never seen one of those ever.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old June 5, 2013, 09:55 AM
3.0charlie's Avatar
Never saw that in all my web searches.
Hydro-Quebec is salivating...
Old June 5, 2013, 11:44 AM
sswilson's Avatar
I've never seen one either, and I suspect that since 12V DC adapter sizes aren't standard they probably don't exist.
Only thing I could suggest would be to pick up one of the laptop universal adapters for the DC adapter part and then solder the leads from that onto the pins of a molex fan adapter.
Old June 10, 2013, 04:23 AM
I wouldn't suggest such a thing after my experience trying to wire an external HDD to a computer power supply. When I flipped on the HDD the computer would restart (and this was a Seasonic M12 PSU). I'd assume some stuff that accepts a "12V DC" from an adaptor present a load that the computer PSU is not used to, maybe too much capacitance or static electricity from not being grounded properly that make the PSU unstable.
Old June 10, 2013, 07:36 AM
KaptCrunch's Avatar
the issue may been that polarity was wrong to restart system or PSU 12v was over loaded by the ext.HDD
add a 2.2k MfD electrolytic capacitor to line watch polarity stripe goes to negative
no problem here doing what SSW said just added the cap for a buffer
mind you my 12v rail has 87 amps yours was 24 amps
Old June 10, 2013, 07:39 AM
KaptCrunch's Avatar
Molex cables ? bostonkikiki Storage 9 February 2, 2013 09:12 AM
Molex Fan Adapter Problems?! AdamHuw New Builds 3 June 6, 2012 05:15 AM
2 Molex to PCIE Adapter RLP06 Video Cards 3 June 1, 2010 04:56 PM
Molex Alternative? Xillion Peripherals 7 August 11, 2009 05:46 AM
4 pin molex connector Phobia Off Topic 9 June 2, 2009 12:59 AM
