Old June 4, 2013, 08:21 PM
Default Powersupply fan noisy when mounted vertically
I recently got a FT02 and mounting my XFX 850pro in the vertical position, the fan now makes a soft but sure ticking noise, and it has noticeable bearing noise. When laid flat, it is still silent.
Has anyone else encountered this? or is it unique to the type of fan bearing used in this PSU?
Old June 4, 2013, 08:49 PM
certain fans will only work in one position. sounds like you have one.
Old June 4, 2013, 11:08 PM
Is this the bronze rated or the gold rated pro?
Old June 5, 2013, 11:27 AM
It is Silver rated.
XFX Pro 850W XXX Edition review | Expert Reviews
That's a shame, really like this psu too. Probably trade for a different one.
Old June 5, 2013, 04:51 PM
It is Silver rated.
Its the difference between ball bearing and fluid bearing fans.
Old June 9, 2013, 06:06 AM
It seems to be a ball bearing fan, could it be just a bad fan?
Old June 9, 2013, 06:54 AM
sswilson's Avatar
If it's still under warranty I'd get in touch with their support guys, if not i'd crack the seals to see if the fan is replaceable.
Old June 12, 2013, 02:47 AM
Default fan
I've come across fans that make much more noise at certain orientations. Usually a worn or defective bearing is the cause.
If it's not under warranty you could open it up and replace the fan... Just need a soldering iron & screw driver. Be sure you wire it correctly though!
Or if the bearing is exposed you could try putting a tiny dab of oil in it.
Old June 12, 2013, 06:54 AM
KaptCrunch's Avatar
peel off half of sticker on center fan hub to get to bearing
Noctua NH-U12P Mounted on an Angle Snarl Air Cooling 5 July 8, 2010 04:42 PM
Bottom mounted psu and carpet FlyingFish Cases 17 May 8, 2010 07:29 PM
Noisy Fan on PSU Kayen Power Supplies 6 August 29, 2009 11:58 AM
Computer mounted on Corkboard? Infiniti Off Topic 7 August 30, 2008 03:17 AM
Cosmos watercooling question - top-mounted rad... Synth Water Cooling 8 July 19, 2008 12:03 PM
