Old May 31, 2013, 11:03 PM
grinder's Avatar
Default leaky battery
Replaced a PSU battery today... very typical considering the batteries are a consumable item. First ever "leaky" battery tho. PSU still operates fine with the replacement... enyone else have a hand full of battery acid trying to replace a PSU battery? ick
Old May 31, 2013, 11:13 PM
supaflyx3's Avatar
I wasn't aware PSUs had batteries, nor have I disassembled one because I enjoy not being dead. o.o
Old June 1, 2013, 12:18 AM
dustin1706's Avatar
I'm assuming you mean UPS instead of PSU? I had a battery swell and leak in a ups but it was only about 15% more expensive just to replace the whole thing.
MSI GT72 6QE-033US - 6700HQ, GTX980M, 1080p G-Sync IPS, 16GB DDR4, 1TB Evo 850 SSD, 256GB Toshiba SSD, 2TB Barracuda, BD-Rom/DVD-RW
Old June 1, 2013, 05:21 AM
Soultribunal's Avatar
Most of the time the VRLA batteries in UPS units will rarely if ever leak even at their EOL stage.
Only the really really cheap ones from China.
There are actually good battery dealers nearby myself. I can get Japanese batteries for most UPS units much much cheaper than a UPS.
My APC 1300 XS , I got its replacement batteries for $19.23 each *needs two*. The same UPS to buy would have been $200 :)
I have had some UPS batteries in the bigger KVA units leak though. Makes a mess.
Baking Soda FTW.
-ST
www.realhardwarereviews.com
Old June 1, 2013, 09:25 AM
grinder's Avatar
late night posting
Yeah this model is a china-special... guess I know better now.
Old June 1, 2013, 09:37 AM
The little batteries that are encased in plastic are notorious for doing this. Usually getting to warm or overloaded then they expand and POP make a mess :( Most UPS systems are a write off when this happens but the odd time you can be lucky and have no issues.
Old June 1, 2013, 02:41 PM
t0m's Avatar
t0m t0m is offline
i made a thread here when mine popped. it didnt appear to leak though, the battery was full of white dust and the inside of the unit was dry. the ups is fine with a replacement in it :)
nothing left and nothing right
Old June 1, 2013, 03:21 PM
'Proper' VRLA batteries , that is what will happen to them.
I remembery your post well actually.
Usually the Taiwan / Jap batteries are good for not making a mess when they fail. But, as part of any thing else I think anyone who uses a UPS should check them twice a year.
I do, and it prevented an issue when the XS needed new ones.
Ounce of prevention beats a pound of cure anyday.
-ST
Old June 1, 2013, 03:37 PM
t0m's Avatar
t0m t0m is offline
i just went back to have a look at that thread and got all warm and fuzzy inside. thanks again for all your help :)
Old June 1, 2013, 09:33 PM
KaptCrunch's Avatar
Baking Soda FTW.
-ST
nada on the baking soda (bubbles) for leaves a acid for your fighting a acid with a acid
rinse really well after to wash away active residue, otherwise will lift off plating on battery tray.
if leaking/swelling battery, is the unit overcharging battery.
Charge battery outside laptop/ splice power to battery contact clone63 Troubleshooting 4 September 1, 2012 06:24 AM
What to do with a leaky dehumidifier? jcmaz Off Topic 5 June 24, 2011 03:18 PM
Leaky battery - help! Tempstar New Builds 10 April 23, 2011 05:31 PM
[WTT] my w510 9cell battery for your w510 6cell battery elninio Buy/Sell & Trade 0 December 29, 2010 12:16 PM
help with leaky tfc 45 rotary compression fitting! antiacid Water Cooling 7 May 11, 2010 11:49 PM
